Results 1 to 4 of 4
    hi,
    is there a difference between the two? i am due to tranny oil change and i am looking into rp.
    Apr 2008
    migs would be the authority here as he sells the stuff...
    i believe that synchromax can be for any vehicle even 4x4.
    max gear is for heavy duty 4x4 or truck use.
    depending on your vehicle, you'll find a RP product that will suit your needs.
    i'll be using it for a front wheel drive manual tranny. mitsubishi lancer 2k glx in particular f5m41 tranny. according to my manual, i should be using 75w90 or 75w80 hyphoid gl-4 or higher compliant
    Nov 2003
    rp synchromax can be used on trannies that require thinner gear oils like honda (non-lsd) and getrag trannies.
    rp max gear can be used on most of the other trannies/differentials/transfer cases
rp synchromax vs maxgear - what's the difference?
