Results 1 to 4 of 4
    May 2007
    hello mga sir
    ask ko lang mga sir kung gano katagal bumigay primary and clutch disk? kc ung primary bagong palit nun MAY and nasiraan me ng repair kit last sept lang tapos ngyn bumigay na naman. last month pinapalitan ko lng repair kit sa mekaniko sabi nya may gasgas na rin daw ung primary and baka may problema na rin daw ung disk kc matigas dw ung clutch ko pg binobomba nahirapan itulak ng primary ung fluid kaya bumibigay, e la pa me budget kaya un lang muna pinagawa ko, tapos ngyon bumigay na naman..nag pa quote me dun sa talyer n un ASIAN AIRE service center, caa road las pinas here are the parts and labor:
    pull down transmission for chk-up..........1700php
    pressure plate...........1050php
    clutch disk........1550php
    release bearing..............680php
    primary clutch..........1100php
    pls advise mga sir if reasonable ung mga price or hanap me sa iba
    tnx a lot mga sir
    p.s. ung clutch disk nga pla 2-3years na nun pinalitan nkausap ko p ung binilhan ko car, my car pla corolla gl 90' 16valve model
    the price is a bit high .. pero that is what you expect from a service center ...
    pero usually yung tatlo sabay ang palit (clutch disc, pressure plates, release bearing) kasi pag magtipid ka in the long run masisira agad yung parts mo ... either may gasgas yung pressureplate mo , sunog yung lining or sirana yung release bearing mo ... either way palitan mo na lahat
    the parts are oem price ... i guess aisin and brand na bibigay sa iyo since toyota yung car mo ... clutch master is about 800, cluctch disc and pressure plate is around that area pero baligtad yung price mo usually pressure plate is more expensive, release brg is about 400 - 500+, and the labor is about 1000 - 1200
    questions call me nalang
    BANAWE AUTO SUPPLY
    7120115
    regy
    Feb 2006
    yup, the price is a bit high, sakin kasi before i bought the parts myself sa pasay, so i got them almost half of the price you posted plus orig pa nakuha ko parts. pero yung labor is the same, mine before was 1.5k
    May 2007
    sir recklus san sa pasay ka nakabili? evangelista? tsaka san ka talyer nagpagawa d2 las pinas area?
    sir banawe, contact na lang kita within this month kung d pa me nkabili
    tnx mga sir..
clutch problem..pls advise
