Originally Posted by
jick.cejoco
what is the mileage of the car? who had been driving it, was it a novice driver or a seasoned one. where was it usually driven? has there been a leak of oil at the rear of the engine? if the clutch was worn out, i would recommend replacement of the clutch disc, pressure plate, release bearing, pilot bearing, rear main oil seal as a set. this sounds like a lot of parts replaced but the difference in the cost of just having the clutch disc relined and everything else as is is not cost effective specially the labor for this operation is not that cheap. if maybe it was a jeepney, maybe yes since the accessibilty of the clutch and associated parts replacement is easy. take care of the MAW (might as well parts), ti will save you money and it will save you from the inconvenience and waste of time
