Results 1 to 13 of 13
    Apr 2008
    Question naman po...
    1.) Bakit po kaya matigas ang apak ko sa clutch? Napansin ko kase ito nung nakatry ako gumamit ng 96 corolla gli and 2005 ford lynx. Malambot ang apak ng clutch nila compared sa 96 hnda civic vti ko.
    2.) May sabit ang gear pag nagshishift. kahit todo apak na saclutxh ganun pa din. Napasok naman kaso hindi smooth compared dun sa mga cars na nasabi ko sa question 1.
    Thanks in advance sa mga magrereply
    May 2007
    Change the tranny fluid to the type and weight recommended by Honda Your clutch is'nt really adjustable as it's hydraulic. I would guess the oil in the tranny are too "heavy" or "wrong type".
    Apr 2008
    Quote Originally Posted by v6dreamer View Post
    Sir tranny oil ng honda yung nilagay ko. Kaso hindi pa ako nagchange tranny oil ever since. dagdag lang.
    Aug 2003
    wow, puro dagdag lang ng oil without draining since 96? madami ng dumi kasama sa oil nyan. nagde-degrade din yung oil so isipin mo nalang yung degraded and dirty oil sinasama mo pang lubricate sa tranny mo.
    you should have this checked up by your trusted mechanic/shop.
    Oct 2007
    Bro, Sometimes nag babara dahil sa dumi ang mga butas ng master at slave cylinder mo, check mo na din ang pipe/hose kung may dent, pero minsan kapag luma na ang pressure plate ay natigas din kasi nalalim na ang mark ng release bearing sa finger nito dahil sa tama at tagal na din..
    Apr 2008
    *roninblade, na-drain na pala to 1 time. nung 50tkm. ngaun 90km na nde pa nadrain ulet. Yung brake fluid pala ng primary and secondary clutch hindi pa nadrain ever since and puro dagdag lang.
    *stryke1, cge sir papacheck ko
    Nov 2003
    if the pedal is hard it could be the pressure plate or release bearing that's getting sticky na. if it's hard to shift replace the gear oil with the proper viscosity one. hindi dapat 90 gamit sa honda.
    Apr 2008
    Quote Originally Posted by speedyfix View Post
    Sir speedfix, ano po ang right viscosity para sa honda ek?
    Nov 2003
    30 or 40 weight engine oil for honda trannies na non-lsd.
    add ko lang din po.. mine is also doing the same thing...
    On my 96 ek may sinasabi yung mechanic ko about putting a rod that puses the clutch in. So konti apak mo lang pasok na. Is it true?
    TIA!!
    Nov 2003
    that's stupid... if you put a rod that partially engages the clutch then super bilis ubus na yun.
    you might want to change mechanics.
    Oct 2008
    adjust clutch freeplay only...
    Nov 2003
    yeah, when you adjust the freeplay the bite will also be adjusted. that's all you should do.
Clutch and gear inquiries
