Originally Posted by
JAZ333
pasinget ha?!
saan ba banda or rather how to refill clutch fluid?!
madali lang ba pag DIY?!
para lang bang naglalagay ng brake fluid yon?!!
this is one thins kasi na hindi ko pa nache-check sa car ko.... clutch system.
Dali lang yun sir.
Sa tabi nung lalagyan ng brake fluid is another lalagyan. If you're facing the car, sa right yun. pag salin mo nung fluid dapat hanggang dun lang sa maximum level kasi masama pag sobra, I think overflow un. Be sure that you only use the right fluid. :wink:
I had an experience once. Sama pa nga kasi sa express! :? Better check the level first bago kayo alis and the brake fluid level na din. Nandyan nakasalalay buhay natin. :wink:
