Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Guys, just recently I noticed that the level of the clutch fluid at the reservoir in my car has been decreasing. I need to refill the fluid every week or two above the minimum level. For the past 9 years I haven't experience this in my car. I have no problem with shifting gears (MT) nor noticed any changes when I stepped on the clutch. What seems to be the problem? Thank you for any info you may share.
    Simple... May leak.
    the leak can be anywhere from the reservoir to the slave cylinder by the transmission housing.
    a thorough visual inspection should flush out the culprit.
    replacement or repair kit. both have their merits.
    Jun 2006
    ^^ what dr d said. My guess is its the clutch master.
    Oct 2013
    Wag ka mag-alala, kung hindi ka magpalit ng repair kits sa primary master or sa secondary master ng clutch mo , pag apak mo ng clutch di papasok ang kambyo mo.
    Quote Originally Posted by vvti2.0 View Post
    bossing naman.. lalong mag-a-alala yan..
    but i am sure we all had our story of bringing home the car on only one gear..
    LOL, and at one time any gear wont engage at all or magmamalay na lang sya lusot na ang clutch..
    Seriously, peep in the plunger just behind the pedal and firewall. Check also the slave near gearbox.
    Look for wetness. Wetness = leak. This problem is common to old cars and those not flushing the system. Hygroscopic fluid collected much water enough to corrode metal parts then damage the cylinders/pistons. If your reservoir has this murky rust color in the buttom, that's your first symptom for damage due to corrosion.
    Sep 2012
    Aside from the items stated above, a simple test to do is to rev the engine while parked to 3,000 rmp.... pag biglang nag white smoke yung sa tambucho and may amoy fluid, then may leak yung gasket sa loob ng hydrovac...
    Rare lang ito nangyayari but it doesn't harm to check na rin
    Sir, so far no rust color at the bottom. is it expensive to fix this kind of trouble?
    Quote Originally Posted by restituto View Post
    it depends on what part is leaking. masters are, i think, more expensive than slaves.
    it also depends on whether it can be fixed using a repair kit (cheaper), or needs replacement (expensive).
    but fixing it is a straightforward thing with few surprises.
    errr... have it fixed while you still can drive it. not very many mechanics make house calls now, and sometimes, it entails several trips to the parts store to get the parts...
    i usually bring the car to the parts store and have the mechanics in the area do it.
    how much? i'm out of the circle, as mine hasn't needed fixin' for some time now. last time i had one fixed was in 10 years ago.. koreano pa..
    tell you what.. call up a few stores for quotes on prices of master cylinder and slave cylinder of your car model. that should give you an idea. then add 500 kesos for labor and 200 bucks for the fluid..
Clutch Fluid Level at Reservoir decreasing
