Originally posted by crossback eh sir ungas, assuming naka high settings nga clutch ko, ano po drawback nito? do you think i should return/adjust it to "factory or normal settings"
txs sa reply!
Your clutch lining will fade faster than any normal usage. Mangagamoy sunog palagi ang clutch mo. More fuel consumption, kasi hindi fully transferred ang engine power sa wheels. Worse, baka idamay pa ang sira sa flywheel, which will cost you more.
Every mechanic will advice you to restore it back to normal adjustment. Anyway they should do that and always comes with the service.
