Results 1 to 5 of 5
    Dec 2003
    Hello,
    Just tonight naputol ang clutch cable ko. So had to go clutchless driving. Since its a Daihatsu Feroza baka mahirapan ako makahanap ng replacement.
    Just incase I can't find a replacement, where can I have a clutch cable fabricated or repaired? Ang putol ay sa may hook sa clutch pedal side. Thanks.
    Dec 2003
    Today I had a pleasant surprise. First shop I went to see if they have a clutch cable, had a Feroza clutch cable. I even asked, if for what car the cable was for, tts actually for a Feroza. Its been years since this has happened to me, its normally hunting the part from different shops.
    For the benefit of others the replacement cable is:
    Federal Mogul CC-3313
    430 pesos at Prens near Toyota Alabang.
    kahit siguro ibang brand basta almost the same ang length. hindi na ata pedeng repair ang cable.
    Pwedeng i-welding pero stopgap/emergency solution lang of course.
    Dec 2003
    Thanks for the suggestions. Grabe nahirapan ako ikabit ang eye ng clutch cable sa hook ng pedal, ang sikip.
    Pag dating ko sa bahay binasa ko yung service manual sa PC. Tatangalin pala ang isang part ng dashboard at ilang electrical coupling para maaccess. Next time I better read before doing the work
clutch cable fabrication or repair
