Results 1 to 6 of 6
    Dec 2010
    hello tsikot masters,
    ano po ba ang best way to pro-long the transmission of an automatic engine during traffic??
    ang habit ko po kasi ay nilalagay sa nuetral pag ka fullstop then shift to drive ulit..
    may tropa kasi ako na nagsabi dapat daw po e drive lang tapos brake na lang pag traffic.. meaning no need daw to shift to nuetral..
    alin po ba ang tama para mas tumatagal at maingatan ang transmission ko?
    thanks!
    Dec 2010
    na double post pa.. sorry pano ba delete tong isa??
    Oct 2009
    Traffic > 15 secs, use N
    Else use D
    Jun 2006
    makisingit narin po, Pagkakaalam ko di pde hatakin ang kotse na a/t.
    Pero masama pa din ba ma-tow kahit na naka N ang tranny mo?
    Dagdag ko na din, is it bad to coast in N while decelerating from 100 to full stop?
    Curious lang naman.
    Feb 2009
    Quote Originally Posted by shibby75 View Post
    Curious lang naman.
    most cars are okay to tow within 25 miles and up to 35 mph in neutral. check your owner's manual. decelerating in neutral is okay, the only thing you are missing is engine compression braking
    Dec 2008
    kung stop and go ok lang sa drive pero kung total stop just like Battlestar said, shift to Nuetral. this lessens stress on your tranny.
    btw, here is a link where you can find really what matters most in taking care of your A/T.
    http://www.samarins.com/maintenance/transmain.html
taking care of a/t transmission
