Results 1 to 10 of 10
    Feb 2004
    i usually noticed this when shifting on 1st gear and 2nd to 3rd gear.
    what caused this?
    naramdaman ko lang to nun nagpalit ako ng 1 set daikin clutch assembly.
    worst scenario, npabayaan.. nu mga tatamaan at delikado ba to?
    how can i remedy this?
    many tnx...
    ~noelt.
    Nov 2003
    could be sa adjustment lang ng clutch.
    Feb 2004
    nkaka 1 year+ na sir migs since it was installed. pde pa bang mahabol yun? kng hindi mahahabol nu dapat gawin? delikado ba to?
    Feb 2004
    UP ko lng. any comments guys.
    Yan ang problem pag replacement parts ang ginamit sa clutch assy. Always stick to OEM pag clutch na especially diesel rides.
    Feb 2004
    they say DAIKIN is almost orig since same manufacturer yng OEM at DAIKIN clutch assembly.
    Mar 2003
    yun nga ang sabi! pero price difference is very far apart...i almost used a daikin when i replaced clutch but when i was advised to get the OEM nalang para walang problem at mas recommended for 4wd kse mas sturdy talaga at heavy duty...so i ended up getting the Exedy. (OEM for isuzu)...no regrets.
    Dapat pina reface mo rin yung flywheel pag nagpalit ka ng clucth disc at pressure plate.
    ano ung clutch drag? sori walang alam. hehehe
    Nov 2003
    baka pero it will be hard to tell without seeing the car.
    we've had no problems so far and i think we hvnt used oem in a while. fcc, daiken, asco are all allright brands. actually, if you look at oem clutches they have the same part number as the replacements. same as the bearings... kaya fiasco talaga mga casa minsan.
clutch drag
