Results 1 to 4 of 4
- Mar 2007
- 26
February 28th, 2011 05:30 PM #1bumili ako repair kit for secondary cylinder to have it changed.after mapalitan tumigas clutch tpos may ingay cia pagapakan.squeaking sound.sabi ng nagpalit may kelangan lang daw lagyan ng grasa.nakalimutan ko kung nung exact part ung grasahan.normal lang ba na tumigas ung clutch at magkaingay after mapalitan?iba ung feel nya compared before cia palitan.
February 28th, 2011 05:52 PM #2
Dapat hindi sir.
Kaya nga pinaayos mo yan para almost back to normal. Plus the sound is disconcerting considering na dati wala niyan. Ipa-back-job mo agad sir. Sabihin mo na hind naman ganyan dati. La ka kamo peace of mind.
Na-check mo ba sir if yung repair kit is ideal for your car? na-check mo ba na yung pinalitan at yung repair kit ay same yung dimension/size/appearance?
- Mar 2007
- 26
March 1st, 2011 06:06 AM #3
March 1st, 2011 10:56 AM #4
mukhang nagalaw ng siraniko este mekaniko mo yung orientation ng release bearing-fork assembly ah.....squeaking sound high pitched? usually moving part yan not in the hydraulic circuit.....
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
