Parehas lang ba ang ginagamit na fluid sa brake at sa clutch?
Kase diba sa power steering fluid iba ang gamit.
brake and clutch fluid - pareho
power steeringand A/T fluid - pareho
hth dre :wink:
b2y,
Would help if you specified your ride. Honda uses a different PSF, not the usual ATF.
And MOTUL recommends that you use its high end brake fluids (RBF 600 and DOT5.1) FOR THE BRAKES ONLY.Likewise with CASTROL and its SRF.
