Results 1 to 7 of 7
    Oct 2005
    guys, iv suddenly had a problem with my bighorn. could anyone pls tell me a shop where i can have it checked and fixed. here are the symptoms:
    1. speedometer stops working
    2. "O/D Offlight starts blinking
    3. delayed shifting occurs
    4. Overdrive does not engage...
    Iv searched the forum and found out it has something to do with a speed sensor.. any shop you could recommend?
    Oct 2005
    hi, il be going back to baguio tomorrow. if anyone could recommend a shop, plesase text me the name and lcoation
    09178977798
    .. i would really appreciate it.. thanks..
    bon
    Nov 2003
    go to banawe and have them look for a compatible speed sensor for your car. you should have no problem finding one there.
    Jun 2004
    sir speedyfix, can you guys diagnose isuzu bighorn/trooper a/t tranny? 4jg2 siya. having problems kasi with the shifting of gears. thanks.
    Aug 2007
    Updates? Naayos na po ba mga automatic transmission problems nyo Sirs?
    Nov 2003
    nope, my computer cannot diagnose them... bring it to an isuzu specialist nalang imo.
    Aug 2007
    My Bighorn (4JG2 A/T) has a switch near the Transmission Selector Lever that toggles between "Power" and "Normal" with corresponding indicator light in the dash. I understand it suppose to alter the shifting points but I can hardly feel the difference. Any ideas how to test if this is still functioning?
    I am beginning to suspect that it is somehow stuck in the "Power" mode because it downshifts with just a little pressure in the loud pedal (also very sensitive)
Bighorn Automatic Transmission problem HELP!!!
