Results 71 to 80 of 89
- Jun 2010
- 1
June 14th, 2010 04:25 PM #71just a clarification, kasi i bought a lancer mx 2005, ngayon lang ako nakapagdrive ng automatic: kapag ba naka invecs, do you need to step off from the gas pedal when changing gears (plus or minus) like in manual transmission or pwede ng naka-steady ung paa sa gas kahit nagpapalit ng gear?
also, may possibility na ba na mamatayan ng makina ang automatic while in D?
yung sa akin kasi, kapag traffic, umaabot sa 600 ung RPM kapag naka D tapos naka brake lang ako, nanginginig na parang mamatayan ng makina although hindi pa naman namatay sa buong gamit ko ng 1 month.
Thanks.
- Nov 2006
- 201
July 27th, 2010 01:56 PM #72mga sir alin ba ang tama tungkol sa cable adjustment ng AT:
more slack-ealier shift
lesser slack-delayed shift or the other way around?
- Jul 2010
- 48
August 4th, 2010 08:34 AM #73bago ba ikakabit or surplus lahat? bearinga para san? I drive 95 galant supersaloon. ito prices two years ago
1) surplus tranny - 9k
2) bnew servo - 8k
3) bearings??
kung kit lang yan, sa eldo rado ka bumili ng kit, plastic lang yan walang 500 pesos. pero kung tunaw yung parang asbestos sa ilalim ng servo+ throttle body, palitin na servo mo. yung bearings naman, bearings ng ano at para san?
tranny cost went high daw dahil sa sobrang demand at low supply nung ondoy case. di ko lang sure kung nag back to normal na mga prices ngayun..
- Jul 2010
- 48
August 4th, 2010 08:36 AM #74mahal yan! servo kit baka 500 pesos lang, made of plastic. kung tunaw na yung parang asbestos sa ilalim ng throttle body mo, palitin na servo mo.
kung surplus tranny naman, di ko sure kung nagnormalize na costs ng surplus ngayun after the demand nung ondoy.. got my tranny for my 95 galant at 9k two years ago.
yung bearings, bearings ng ano?
August 30th, 2010 12:52 AM #75
mga guru, i have one pretty big problem. i have a matic 2006 ford focus, just over 30k ang mileage, maingat po kung gamitin. kanina po nung nilabas ko ang auto from our garage and had it parked sa street, parang biglang nawalan ng resistance yung shift lever nung nilipat ko na from D to P, nakacomplete stop na po ako nito. so tinest ko ulit yung lever only to find out that the transmission doesn't change modes kahit san pa nakatutok ang lever. so kahit ilipat sa R, N, D, + or -, yung mode is still on P (as shown on the dash lcd display). wala din kahit na anong error na lumalabas sa display. so hindi ko sya mapatakbo and hindi din pwede itulak, kasi P ang mode nya kahit ilipat mo sa N.
isip ko baka naputol yung control cable. any intelligent hunches? thanks!
- Aug 2010
- 32
August 31st, 2010 09:57 PM #76Baka yung cable ang sira nyan.
Sa A.M. Bulaong try nyo mag inquire. They're located in #34 Kaliraya St. Banawe and look for Leonard Bulaong Tel. 7496586.
September 2nd, 2010 08:25 PM #77
yup, cable nga bro. natanggal lang sa linkage so i spent some time and fixed it myself.
- Feb 2010
- 194
October 22nd, 2010 06:05 PM #78Mga bossing, please help. . . This is about my A/T Crosswind.
After being idle for about 4 days, ayaw na magengage sa 4th gear or last gear crosswind ko. PArang palaging lang naka-off and OD. . .Its as if nasa 3rd gear lang ako palagi kahit mataas na RPM ko. . .hanggang 70km/h lang takbo. . .naka-off or naka-on and OD, walang pagkakaiba. . . Ano kaya ang defect ng car ko. . . would it just be electrical or transmission na. . . Bago lang palit ang ATF ko so i dont think ATF ang problem. . .
Thanks in advance. . . .need your advice. . .
October 30th, 2010 11:36 AM #79
Boy, am I glad I never bought an Ecosport!
BYD Philippines
