Originally Posted by
emdee_27
Galant Super saloon 1997 A/T
Incident: on a stop and go trapik, nabigla ko ang apak sa accelarator, na paiyak ko ang gulong sa bigla at malakas ang biglang arangkada ng kotse.
later on, after parking for a whole day at pauwi na, i shifted to drive, walang response... antay for 1 minute...nothing happens, shifted back to neutral and back to drive...nothing happens, when i shifted back to drive, 2nd and L... wala parin
but.. when shifting to reverse, engage agad at walang problema.
I need to shift to drive, and then press the accelarator...umaabot ng 2000rpm bago mag engage drive...kaya laging kumadyot ang kotse.
i test drive it.. pag nasa drive na at umaandar no problem sa shifting, lahat ng shift at nag down shift... ang accelaration wala din problem.
na feel ko lang lagi ngayon, everytime a made a full stop from a relatively high speed where i think na nasa high gear ako ... na feel ko pag full stop pag nag downshift na sya to 1st gear, me shift shock na, dati wala.
walang nag blink sa gear ligths walang ibang ligths or check engine din na naka ilaw.
the ATF was changed last year including the strainer/filter. the ATF doesnt smell burnt... kulay pula pa color.
I have it checked sa rapide, they changed again the atf, pull down the oil pan, changed the filter, then made a diagnostic test sa ecu... walang nakitang error code.
verdict nila; nasira daw first gear, me kumalas daw at kelangan palitan ang buong transmission... a very expensive quote ang sinabi
need your help... advice... suggestion... me naka experience na ba ng ganito sainyo
thanks...sorry for a long explanation
