Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Jul 2013
    Question lang po for AT/CVT/DCT
    How many KMS before overhaul?
    I did my research kasi and most na lumabas is kapag tumigil na daw, it's time for an overhaul... Ayoko naman abutan na tumigil na lang bigla yung sasakyan...
    Based on experience... Once it "slides" its time... Pero as a guide for others... Ilang KMS bago maghanap ng AT repair shop
    Jul 2006
    I will speak for AT.
    You cant really tell.
    Its not an exact science.
    Plus, its how one maintains his/her AT that determines on how "long" it will last.
    I have a friend who is very praning on his tranny giving up on him. So I told him to buy a used tranny, have it overhauled and keep it as a reserve.
    That is what the guy did.
    like benzy says, "it depends on the maintenance".
    i know of somebodies who are in the 100K odometer reading, and yet their AT is ok. i am driving one, myself.
    Jul 2013
    Agree with "depende sa maintenance"
    Pero kahit anong ingat natin... mapupudpod din yung clutch nya and will need replacement...
    I was initially hoping nasa manual sya...
    100k kms is basically the end of the car's warranty so dapat ok pa transmission nya.
    Jul 2006
    I have a 114k km. Vios at home. We use it almost everyday. Apart from that, I also have other high mileage AT cars, mostly 70's and 80's models. None of them have had AT overhaul yet. Although I have a car that is showing signs of AT flare and shift delay.
    Yes, the AT is a wear and tear part. So eventually it will fail.
    Jan 2009
    The A/T is similar to a mechanical hard drive. They can run for years until they reach the point of obsolescence without showing any sign of wear. On the flip side, it can also fail way before its time due to bad design, factory defects and/or abuse. However, both share one thing... take good care of them and they will LIKELY last a very long time.
    iyong company car ng late dad ko bumigay iyong tranny just before logging 140000 kms.
    pero hindi naalagaan ng mabuti iyon since company driver nga ang nag-dadala. i think even the casa was remiss because even though the car was brought to them for pms religiously, the guys who worked on the busted tranny said when they opened it up, it was apparent that the atf was far from being fresh even though the car was supposedly up-to-date regarding change of atf and its funky atf filter - w/c was the dead give away for neglect
    properly maintained at least 200k-500k km
    Mar 2013
    Kadalasan nung 90's to 2000 model around 110-120k kms at 130-140k kms eh bonus naman! Hehe.
    Sa cvt dont know pa sa jazz na gamit ko around 99k kms na ok pa naman.
    Don't worry about the number of km traveled before overhaul. Modern A/Ts last as long as their M/T counterparts with good maintenance. Just follow your manufacturer's recommended AT fluid and filter change schedule and just enjoy driving your vehicle.
    Sent from my SM-G920F using Tsikot Forums mobile app
    Nov 2007
    Pa sabay na din po mga sir at ma'am yung Vios ko 2009 model (AT) hanggang ngayon hndi pa ako nagpalit ng fluid at filter 55K kms may nakapagsabi kasi sa akin dati pa na hindi daw pinapalitan ng fluid tama po ba yun? Thanks po sa time
    Quote Originally Posted by kenzie View Post
    ATF replacement schedule should be in the owner's manual, po. ask the casa, if your manual is not available.
    some manufacturers claim their ATF is "for life". many, including me, do not believe this.
    Nov 2007
    Check ko manual master Dr. D
    Dec 2009
    Typical 40,000km ang palit ng ATF
    Walang forever sa sasakyan
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jul 2006
    I had Toyota change mine at 80K PMS. Then its at every 40K intervals.
    fyi toyota atf type4 is not fully synthetic. even the type-ws isnt long life. you have to replace soon.
    Iyong sa akin nga since my ride is getting long in the tooth, annual na ang pagpalit ko ng atf just to be on the safe side
    when you look into the abyss, the abyss looks into you
    You dont like i-overhaul ang matic.
    Mga 200thou or 300thou or pwede 500thou kms bago kailangan baklasin.
    And no assurance smooth shifting.....
    Jun 2005
    Mura lang naman ang T-IV sa toyota casa 1200 per gallon.
    Just recently i replace the ATF every oil change. Mura lang kasi talaga.
    Quote Originally Posted by sirkosero View Post
    ah affordable naman pala. hehehe
Automatic Transmission - How Many KMS Before Overhaul?
