Originally Posted by
pedrosa_bong
You need to rebuild your transmission to secure the leaking of your valve body and reverse clutch assembly. It is not the wrong type of ATF. Specially if it is dextron III or II. you have a two problem, either your clutches in reverse are thin or you have a leak problem in your hydraulic circuit. Its very easy to repair. find a technician that understands the powerflow of your A/T and hydraulic circuit pressure. If you have other questions you can call me 09287618155/7944181.
