Results 1 to 7 of 7
    mods. feel free to merge where this should belong. anyways, i am planning on getting a Crosswind next year. all my driving experience come from 1.6L - 2.0L petrol engines all 5 speed MT... hence, my baseline RPM is 2.8k~3k RPM at cruising speed regardless of vehicle load.
    i posted same question in Isuzu cars talk but i got same 2.8k~3k RPM answer from a 2012 Sportivo owner,, and i am not fully convinced because i believe, diesel engines have higher compression ratio hence lower RPM compared to petrol engines running at same CRUISING SPEED
    Sep 2006
    It's true that diesel engines have lower maximum rpms compared to petrol engines. But your cruising rpm based on a specific speed and selected gear will depend on the gear ratio of the vehicle and not the type of fuel it uses.
    I see. so, I googled some info specific to 4JA1 gearboxes. Hope someone can derive answer of my orig question based on below supplement info:
    Application: ISUZU - 4JA1 ( TFR54 )
    4JA1
    Gear Ratio:I 5.77; II 2.903; III 1.856; IV 1.000; V 0.812; Reverse 5.556
    Central Distance 88mm; Torque 230N.m; Weight 35kg
    Sep 2006
    Google speed/rpm calculator.
    Aug 2004
    Unfortunately, you can't change the gearing (not easily, at least), so whatever you do, the Crosswind will still be doing over 3000 rpm at 100 km/h.
    Best economy for the Crosswind is at the lowest speed in the highest gear you can maintain without pressing harder on the pedal. Which would be around 50 km/h, but that's illegal on the expressway. Best realistic cruising speed is around 60-70 km/h, which should net you about 16-18 km/l on the NLEX and 14-16 on the hilly SLEX.
    idela rpm for most old school diesel is 1,800-2,200rpm. Change gears in flat surfaces as early as 1,800rpm-2,000rpm.
    *niky & ry_tower: appreciate your inputs. i understand better now.. it would be a great paradigm shift, switching to the old-school diesel like 4ja1.. i guess win win situation nalang siguro, because i'll be needing soon a bigger car that's durable and lesser maintenance w/ lesser electronic components + the ability to carry heavy loads during long drives.
ideal RPM for a 2.5 diesel 5speed MT *100kph cruising?
