Results 1 to 6 of 6
- Sep 2004
- 15
December 9th, 2005 05:18 AM #1Hey guys! Just wondering if you can help me with my automatic transmission problems. I have a Honda Accord that has about 100,500 miles. Every time I shift from park to drive the car jerks immensely forward as though it had just been rear ended & makes a clunking noise. It does this to every gear except neutral. Also when I shift it from drive to park it makes a loud clunking/grinding noise. The transmission is very hard to shift. I have to apply a lot of pressure to the shifter in order to change gear. I had the automatic transmission fluid drained & filled with Honda ATF fluid about 4 months ago & I also added a bottle of LUCAS transmission fix but it didn’t fix the problem. Could it be that my transmission mount is worn out? Do I need a complete transmission flush to eliminate the clunking/grinding? Any suggestions or comments would be appreciated. Thanks in advance!
BANNED BANNED BANNED
- 3,790
December 9th, 2005 05:30 AM #2i think its more than that...baka internals na ang problem...on an ordinary usage car, a 100,500 miles (o kilometer?) is equal na to more than 5 years old. So kung hindi pa yan na seservice sa tranny, malamang meron ng problem ang loob (slipping disk perhaps or something that)....bring it to a professional (preferably sa honda casa) na tunay na marunong sa honda.
- Sep 2004
- 15
December 9th, 2005 05:39 AM #3Originally Posted by wildthing
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 9th, 2005 10:00 AM #4the supports are easy to check. see if there are cracks. if so replace and see what difference that makes.
December 9th, 2005 05:42 PM #5
do the cheapest route muna, change and flush all fluids... clean the mesh filter thing nadin.
hirap sobra diagnose ang AT kasi.
- 3,790
December 10th, 2005 10:34 AM #6100,500 miles would be about 167500kms...8 years mahigit na yan dapat! Not bad...
check mo yung recomendation ni speedyfix and theveed...paghindi nag-improve go casa ng honda.
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
