Results 1 to 6 of 6
    Tulong naman po. I just noticed this morning na may leak yung transmission ko. Saan po ba maaaring nanggagaling yung leak? How much would it cost to fix it? My car is a sentra GA16 manual tranny. TIA.
    Baka sa oil seal yan sir sa transmission mo or crankshaft rear oil seal. Hindi mo ba ma trace kung saan banda yung leak?
    Usually pag nagpalit ng oil seal, baba buo transmission. Pa check mo na rin yung release bearing, clutch pressure plate at clutch disk para isang labor lang babayaran mo.
    No idea sa total price. Wait pa natin mga guru, baka may maganda silang suggestion.
    Nov 2003
    any mechanic should be able to pinpoint where the leak is comming from. have it lifted para makita.
    salamat sa advice niyo mga sirs. baka dalhin ko sa shop tomorrow. bka isabay ko na rin palitan yung clutch kit para makamura sa labor
    just had my transmission leak fixed. Yung mga axle oil seals ang sira. sinabay ko na rin palitan yung clutch kit kahit pwede pa yung current clutch ko para makatipid sa labor. medyo masakit nga lang sa bulsa.
    OEM Clutch Disk P1250
    OEM Pressure plate P1700
    OEM Release bearing P750
    Transmission mount P630
    Oil seal (2PCS) P340
    Labor P1500
    Salamat po ulit sa advise niyo.
    Nov 2003
    ok glad it's fixed na.
leaking transmission oil
