Results 1 to 15 of 15
    Nov 2003
    Guys! umatras ako ng puno ng sakay ang kotse ko na paakyat yung slope towards reverse and i was parking when i was doin this sudennly bigla na nag amoy sunog na clutch sa oto ko. Ano ba effect nito do i need to change my clutch disk or any other na related to this? ano ba effect nito sa kotse? is this a MORTAL SIN ba? pls help need inputs on this kc ngayon ko lang na experience to e. =(
    do you have any trouble shifting now? did you see any smoke?
    worst case scenario, you fried your clutch and yes, it will need replacement....sorry
    Nov 2003
    Well i dont have trouble shifting naman. And i didn't see any smoke basta parang nag amoy sunog na clutch. but i didnt see any smoke naman. and after a few hours na naka park yun car when i left the parking it runs well pa rin just like before. ok pa kaya clutch ko palagay mo?
    Kung one-time lang yung amoy and smoke, youre okay kiddo. ;)
    Nov 2003
    hay sana nga you're rt pajerokid. Ano ba cause ng ganun sa clutch? sobra kaya nababad yung paa ko sa clutch?
    most probably..nababad nga lang ang paa mo sa clutch.
    pakiramdamaqn mo kung nag s slide...pero kung hindi naman..ok pa naman yan...
    ize_9, yup. You probably revved too hard too long with the clutch engaged. Dont worry, it happened to me too. as long as nawala na yung smell and smoke and your clutch still operates normally (walang slip), youre good to go! wag mo na lang uulitin hehe
    pagpababa ka ng baguio using engine braking may tendency na umamoy ang clutch. sa lions head kennon road pag nag stop-over ka maaamoy mo yun clutch ng other cars. ok lang yan, wag lang madalas.
    Nov 2003
    ok guys! tanx alot for the info =)
    Nov 2003
    ok pa yan clutch mo. i just hope it's not warped yet. just try to avoid this in the future. also, try not to do hanging to much. if you're on a slope, just put it in neutral, engage the handbreak and when you're ready to move again dun ka palang mag shift sa gearÜ
    hope this helps!
    we have the same case sakin lang were in a convoy sa burol at inclined road at sobrang puno ung oto kaya aun amoy sunog hehe. kaso lang ung sakin bumabalik ang amoy (konting amoy) eh kapag medyo kelangan ko mag clutch/gas like in inclined o puno ung sasakyan o mag papark ako in reverse kapag may load pero normal pa din naman ung shifting at im sure hindi naman sliding, whats unusual lang is pag full pack yong sasakyan eh from stop then ill give gas then slowly disengage clutch, eh medyo mag vivibrate ng konti . first time to nangyari sakin. ano kaya to? clutch lining replacement o adjustment?
    Quote Originally Posted by Sardinas View Post
    Generally, unless you have totally abused the clutch for a long time, it should be fine. Just be easy on the clutch for the next few kilometers for the overheated surface to cool down.
    If the clutch still vibrates after a while, it is possible the clutch disc might have gotten "glazed over". If this happened, you'll need to have the clutch disc / flywheel serviced or replaced.
    Apr 2010
    advise ko sir, pacheck mo sa transmission specialist na to...mura lang maningil at ieexplain sayo at bibigyan ka ng options...sabihin mo lang refer ka ni marvi...
    mang rey
    09308515383
    9373983
    Follow up questions lang po.
    Vehicle suzuki multicab f6a (12valve).
    Engot kasi yung driver, ginawang tricycle na 2stroke, nag clutching2x nung bumara sa putikan, nangamoy sunog na lining pero ang masaklap afterwards ayaw ng mag disengage ang clutch (kabaligtaran sa na experience namin before na ayaw naman mag engage dahil napudpod ang disk). Ok naman ang clutch pedal, feels the same pa rin gaya ng dati, gumagalaw naman ang cable, pati yung sa transmission lever, ang problema hindi na nag disengage ang clutch. Wala talagang clutch.
    Habang patay ang engine, shifted from 1st to 4th gear even to reverse habang tinutulak ang multicab, ayaw talaga kumalas, laging nakakagat ang clutch kahit naapakan na ng todo ang pedal.
    Sinagad ang cable adjustment ng clutch, ganun pa rin.
    Is it possible na sa sobrang init eh dumikit na yung disk sa plate? Palalamigin muna namin, try namin uli bukas ng umaga.
    Less than a year pa lang ang disc plate nito.
    Ano pa kaya ang possible na problema?
    Salamat po sa mga sasagot.
    Dec 2011
    pasubscribe po ako sa thread na to mga master... im newbie here in tsikot.com.. i have this problem po kasi about sa clutch.. kahapon lang nangyari.. nagchange lang ako ng battery.. newly brought battery siya.. then pagstart ko, ok naman.. pero after a minute, biglang bumilis ang menor nya.. i mean tumaas ang menor nya.. bumilis ng bahagya ang makina.. trinay kong laruin ang gasolinador baka sakaling na naghang lang.. pero hindi eh.. walang nangyari.. mataas pa din menor nya.. trinay ko siyang patakbuhin.. ok naman ang clutch switching ko.. pero di naglaon, ngamoy sunog na clutch na.. as in ang baho.. parang patay na daga.. buti at nakauwi pa din ako.. anu po kayang prob ng sasakyan?
    BTW, Owner Type Jeep po pala ang sasakyan, Mazda RF Diesel ang engine.. Thanks po sa mga tutulong..
effects ng nag amoy sunog na clutch?
