Results 11 to 15 of 15
May 30th, 2010 12:31 PM #11
we have the same case sakin lang were in a convoy sa burol at inclined road at sobrang puno ung oto kaya aun amoy sunog hehe. kaso lang ung sakin bumabalik ang amoy (konting amoy) eh kapag medyo kelangan ko mag clutch/gas like in inclined o puno ung sasakyan o mag papark ako in reverse kapag may load pero normal pa din naman ung shifting at im sure hindi naman sliding, whats unusual lang is pag full pack yong sasakyan eh from stop then ill give gas then slowly disengage clutch, eh medyo mag vivibrate ng konti . first time to nangyari sakin. ano kaya to? clutch lining replacement o adjustment?
May 30th, 2010 05:43 PM #12
Generally, unless you have totally abused the clutch for a long time, it should be fine. Just be easy on the clutch for the next few kilometers for the overheated surface to cool down.
If the clutch still vibrates after a while, it is possible the clutch disc might have gotten "glazed over". If this happened, you'll need to have the clutch disc / flywheel serviced or replaced.
June 3rd, 2010 07:21 PM #13
- Jul 2007
- 65
August 28th, 2011 10:15 PM #14Follow up questions lang po.
Vehicle suzuki multicab f6a (12valve).
Engot kasi yung driver, ginawang tricycle na 2stroke, nag clutching2x nung bumara sa putikan, nangamoy sunog na lining pero ang masaklap afterwards ayaw ng mag disengage ang clutch (kabaligtaran sa na experience namin before na ayaw naman mag engage dahil napudpod ang disk). Ok naman ang clutch pedal, feels the same pa rin gaya ng dati, gumagalaw naman ang cable, pati yung sa transmission lever, ang problema hindi na nag disengage ang clutch. Wala talagang clutch.
Habang patay ang engine, shifted from 1st to 4th gear even to reverse habang tinutulak ang multicab, ayaw talaga kumalas, laging nakakagat ang clutch kahit naapakan na ng todo ang pedal.
Sinagad ang cable adjustment ng clutch, ganun pa rin.
Is it possible na sa sobrang init eh dumikit na yung disk sa plate? Palalamigin muna namin, try namin uli bukas ng umaga.
Less than a year pa lang ang disc plate nito.
Ano pa kaya ang possible na problema?
Salamat po sa mga sasagot.
- Dec 2011
- 1
December 11th, 2011 02:58 PM #15pasubscribe po ako sa thread na to mga master... im newbie here in tsikot.com.. i have this problem po kasi about sa clutch.. kahapon lang nangyari.. nagchange lang ako ng battery.. newly brought battery siya.. then pagstart ko, ok naman.. pero after a minute, biglang bumilis ang menor nya.. i mean tumaas ang menor nya.. bumilis ng bahagya ang makina.. trinay kong laruin ang gasolinador baka sakaling na naghang lang.. pero hindi eh.. walang nangyari.. mataas pa din menor nya.. trinay ko siyang patakbuhin.. ok naman ang clutch switching ko.. pero di naglaon, ngamoy sunog na clutch na.. as in ang baho.. parang patay na daga.. buti at nakauwi pa din ako.. anu po kayang prob ng sasakyan?
BTW, Owner Type Jeep po pala ang sasakyan, Mazda RF Diesel ang engine.. Thanks po sa mga tutulong..
Traffic!
