Results 1 to 20 of 20
    folks,
    i need help.
    2003 altis' AT stick refuses to shift positions smoothly. changed the cable already, as the plastic bushing broke and the cable kalas-ed.
    cable was replaced and the car shifts naman. but the stick still does not shift smoothly.
    the gears shift as normal, naman.
    can you recommend a specialist mechanic in MM ?
    thanks.
    Apr 2014
    Baka di tama ang paglagay?
    Too much slack or too tight.
    Quote Originally Posted by chronicle View Post
    it fits fine.
    but hirap i-urong-sulong yung stick.
    para bagang, ayaw mag-ringless sa basket. kailangang masahihin.
    Jan 2008
    it fits fine.
    Isolate the problem first.. remove cable fitting ang check the shifter, cable and the transmission actuator should move freely..
    Check also the cable might be twisted during installation
    Apr 2014
    I can see on a yt channel na may grease na nilalagay on the bushing. Maybe that is what is missing.
    Aug 2017
    folks,
    i need help.
    thanks.
    Try Mario Comeda, shop is at BMA corner Kabignayan Streets, Banawe, QC.
    0921 265 1086/0906 246 1090
    Tell him I referred you to him.
    He converts MT to ATs so he most likely be able to help
    Quote Originally Posted by SidCoronel View Post
    thanks po.
    Apr 2005
    After my recent oil change, Shell mechanic informed me na may leak transmission oil seal. Any recommendation? Is this easy to spot when the car is lifted?
    ^ The main and rear seals ba? Medyo heavy J.O. din iyan because if memory serves me right, I had to leave the car at the shop for a day or 2.
    In my case, the issue showed itself when I noticed that there was a constant pawis on the underside of the car's tranny.
    Apr 2005
    CVT? I might have to go casa.
    If the leak is still small you'll see it as oil/grime buildup on the outside of the leaky part, or if it's a big leak na then outright dripping.
    Mech didn't specify exactly what or where? Transmission oil leak could be anywhere from CV axles, torque converter, pan gasket or main seals.
    Feb 2009
    A good verification is a picture using a smart phone before cleaning the affected area. Personally, I always take pictures for myself and for the customer as evidence. I have used pictures in court for customer's ridiculous claims or avoidance in paying.
altis AT transmission specialist
