Results 1 to 7 of 7
- 54,281
August 24th, 2019 05:21 PM #1folks,
i need help.
2003 altis' AT stick refuses to shift positions smoothly. changed the cable already, as the plastic bushing broke and the cable kalas-ed.
cable was replaced and the car shifts naman. but the stick still does not shift smoothly.
the gears shift as normal, naman.
can you recommend a specialist mechanic in MM ?
thanks.
August 24th, 2019 06:37 PM #2
Baka di tama ang paglagay?
Too much slack or too tight.
- 54,281
August 24th, 2019 06:41 PM #3
August 24th, 2019 06:51 PM #4
I can see on a yt channel na may grease na nilalagay on the bushing. Maybe that is what is missing.
- Jan 2008
- 4,726
August 24th, 2019 07:30 PM #5
- Aug 2017
- 321
August 25th, 2019 10:31 AM #6
- 54,281
Thread was made nung 2018 pa po sir.
