Results 1 to 2 of 2
    Sep 2006
    Hi Guys,
    Question po ulit, pwede ba i adjust ung shifter (kambyo?) kasi parang masyadong restricted ung movement nung shifter eh. Example pag shift ko sa reverse kung minsan d ko napapansin na sa 4th gear pala nakalagay.. parang d ko kasi maramdaman na pumasok sya sa reverse..
    THanks!
    Aug 2006
    I have never heard of an "adjustable shifter lever"... However, I know for a fact you can get a short shifter/short shifter kit (if there's one made for your car) that shortens the shift travel by increasing the distance between the pivot point (joint) and where the shift linakge is attached...
    here's a pic of Integra shifters, the black one in the bottom is the stock one...
Adjusting the shifter?
