nasanay kasi ako sa AT. napapansin ko lang when i shift gears, i sometimes feel that sudden jolt. either when i shift up or shift down. i always try to follow the suggestions here at tsikot to try and shift at around 2000rpm and always fully depress the clutch.
do you guys press on the gas before you fully release the clutch? yung iba kasi yun ang turo. yung iba naman, to release the clutch before pressing the gas.
others depress the clutch for a time before shifting, yung iba quick shift.
yung iba naman, when shifting gears, they just half-press the clutch (as long as pwede na pumasok yung gear).
kayo how do you shift smoothly into the next gear?
