Results 1 to 20 of 37
    Apr 2006
    hi guys -
    nasanay kasi ako sa AT. napapansin ko lang when i shift gears, i sometimes feel that sudden jolt. either when i shift up or shift down. i always try to follow the suggestions here at tsikot to try and shift at around 2000rpm and always fully depress the clutch.
    do you guys press on the gas before you fully release the clutch? yung iba kasi yun ang turo. yung iba naman, to release the clutch before pressing the gas.
    others depress the clutch for a time before shifting, yung iba quick shift.
    yung iba naman, when shifting gears, they just half-press the clutch (as long as pwede na pumasok yung gear).
    kayo how do you shift smoothly into the next gear?
    Aug 2005
    ako di naman kailangan fully depress (as in sagad), pag naramdaman kong hindi na naka kagat ang clutch, shift gears. mejo timplahan din para di ka makaramdam ng shock. as you are releasing the clutch, apply gas.
    baka lang masyado mong binibitawan agad ang clutch before you apply gas..
    Wag mong bibiglain ang bitaw sa clutch.
    the word is SUAVE.
    ganyan din ako dati medyo napapaangat sa sandalan pasahero ko kc ang nasa isip ko di maganda na matagal ang apak sa clutch. di rin naman ok na parating quick release. kaya, tama ang mga suggestions nila... wag bigla bitaw ng clutch pero wag naman sobrang tagal.
    kapag sinabay mo namn ang release ng clutch sa apak ng gas, medyo suave lang sa gas para di biglang akyat rpm mo. ang alam ko kc ang biglang taas ng rpm ay di maganda (tama ba ako?)
    Aug 2006
    PRACTICE... that's all you need. You already know how to drive a MT so it just takes a little more time for yourself to figure out how to be smooth.
    Don't shift gears at 2000 rpm, you stress the rods that way... for a DD just always shift at 3-3.5k, at least that's what's always been adviced... Also, rpm range doesn't have anything to do with smooth shifting, I could shift at redlines all day and I wouldn't feel a single jerk... it's just takes some getting used to...
    Sep 2005
    ang style ko dyan,
    before releasing the clutch pedal, try to match your rpm with the rpm nung bago mo pa tapakan clutch (your shifting rpm), then release clutch "gracefully", mga 2 sec lang yan.
    ang theory ko (ewan kung accurate talaga), for smooth shifting, dapat pareho ang engine speed at speed nung transmission the moment they engage (release clutch)
    pag mas mabagal ang engine speed at clutch engage, they will force to match speed of each other , thus slowing the transmission speed and in effect your wheels. notice also na tataas rpm mo since na-force naman siya ng transmission na tumulin.
    dito mo mararamdaman yung parang sumubsob yung koste pagkabitaw mo ng clutch sa upshift. ibig sabihin kulang pa ang rpm mo. ganun din pag sumubsob ka sa downshift, kulang pa rin sa rpm (since kelangan mas mataas rpm mo sa lower gears at the same vehicle speed) or kulang ka sa preno at mabilis pa yung sasakyan
    pag naman mas mabilis ang engine speed, the transmission (and wheels) will be forced to turn faster to match engine speed. dito naman yung mararamdaman mong very sudden na acceleration
    basta dapat matched ang engine speed (rpm) at transmission speed.
    wala ring rule kung ano dapat mauna, kung clutch release ba o tapak sa pedal
    basta dapat matched ang rpm when engaging.
    for smooth shifting lang to,
    iba na ang usapan kung gusto mo humataw or mag-engine break
    HTH
    Nov 2006
    tama sila wag mong gawin ang quick shift di maganda yan sa kotse mo,,maging praktikal ka kung baga suave lang ang gawin mo,para tipid sa gas,timing lang,try mo itanong sa kanila kung maganda ba na magshift ng gears sa 2000rpm and ano ang difinition ng gear ratio in relation to 2000rpm,dapat icheck nilang mabuti yun kung bagay ba sa kotse mo.
    Aug 2006
    Quote Originally Posted by kenet_3 View Post
    ang style ko dyan,
    HTH
    you're making it hard for yourself... it's just as simple as "rev matching"...
    Jun 2006
    +1
    i believe this is also the reason why you are experiencing jolts while shifting gears. tama sila, practice lang talaga. dont worry, you'll get used to it.
    Jul 2006
    tama sila, pati hanging pag praktisan mo maigi.. yun tipong, full stop na hanging ah,, lagi ako namamatayan dati sa ganun.
    Clutch fully depressed or not, sudden lag comes from premature releasing
    of clutchprior to acceleration. Sayang ang momentum, not to mention
    the gas plus the engine stress it could create. Different engine responses
    differ. Pakiramdaman mo and apply a sort of testing. From simultaneous
    releasing of clutch at the same time pressing the accelerator (kung saan
    sila magmi-meet depende sa clutch adjustment mo) or slightly delay the
    clutch release in relation to acceleration.
    Hi everyone!Im new hear looking for a nice car.Ok ba ang Mitsu GSR?
    Quote Originally Posted by kanky View Post
    Yup,- I assume that this is the 97 and up model (pizza pie) - 2 door. Iyan ang loves kong tsikot,- para kaming mag-syota ng kumander ko....
    :beam:
    Bottomline,- you have to attain the right speed for the gear you're shifting to, (and you don't press the gas pedal that hard, while releasing the clutch o so gently, the latter not really a big factor if you got the first 2 right). There and only then, you eliminate sudden jolt....
    :beam:
how to prevent sudden jolt when shifting gears
