Is anyone install the intercooler to the crosswind? it will be increase the power? or i have to change the biger Turbo? and where in can find the intercooler?![]()
yes, you need a bigger turbo. in fact, you need a whole upgraded turbo/intercooler kit to make decent power out of an intercooler (i.e. bigger turbo, intercooler, reflashed ECU, all the tubes and lines, manifold/wastegate, exhaust/downpipe etc.)
yes you can add an intercooler, you dont need to reflash the ECU because there is none, change the actuator of the wastegate to an adjustable one so that ma increase mo ang boost.
ganun ba talaga pag may ECU, kailangan pang-i-flash?anu po purpose nun?
2c-t ng liteace ko kc may ecu,e....gusto ko din maglagay ng intercooler....(hanapan ko pang ng pwededng daanan ung piping at mounting....) sorry, may pagka-OT,h?
afaik, xuv xwind has low charge turbo? ano ba ibig sabihin nito?
correct me if im wrong...
ung may turbo na crosswind alam ko mga a/t variants.
low charge,im not sure, pero alam ko ibig sabihin nito ay small pressure lang bigay nito, unlike sa normal turbos...para wala atang or minimum lang ang major internal parts na papalitan....
speed ang hanap m s diesel? kung may breads upgrade to next level n mtaas n psi ng turbo wag ssobra stock ung engine eh hindi nka dsign bka casa ang bagsak m after hehe. if u want speed s diesel n wlang kalikot try m to s next fuel stop m: full tank mix of 90% diesel n 10% Kerosine den next 80:20 den 70:30 blive me mor speed ala p usok, subok n yn. bka nga lang mcyahan ka umabot ka ng 40:60 aang laki ng ttulin nyan bka nga lng m2lin krin ppuntan casa nyan hehehe. if u ask my rcmendation mg stik k muna s 75:25 oks n un dka nmam kkrera ng dsel hehe
mga turbo crosswind mga a/t tapos mga ilang horses lang and difference from the n/a.
Medyo OT na to. Naalala ko kasi yong dating driver ng sis-in-law ko. Nag deal sila ng tupperware sa province. Nilagyan ba naman ng reg. gasoline yong L300 na 4d56. Full tank pa. Nang nasa highway sila, bigla na lang nagbago ang tunog ng diesel, bumilis at nag backfire. Nataranta ang driver pati ang sis in law ko kung ano nang nangyari. That's when they remember na gasolina pala na-load ng driver at di diesel. Buti nakabili sila ng galon at plastic hose. Tinanggal ang linya sa tanke at sa galon na sila kumuha ng fuel. Akala ko nga masira yon. Pero noong ginamit ko ayos lang naman. I guess mas okay yong kerosene mo bro. Halos pareho yata ang temp range ng diesel at kerosene.
Anu ba properties ng kerosene at pwede i halo sa diesel?
Crosswind sa tingin ko pinaka ok is palit turbo. Siguro naman n/a components are different from turbo a/t version...
Talagang mahina hatak ng turbo a/t - crosswind xuvi to be specific. i remember i was having a hard time reaching 100++ on star toll.
peso for peso you have to think if you really need more power. it's not as simple as installing the intercooler. you have to have the piping fabricated for it pa .
I also doubt its really necessary to add serious HP to the Crosswind since it's not even designed to handle high speeds safely (esp. the XTRM and up models with bigger tires and lifted body). The main reason for the being of that vehicle is utility.
Again: DO NOT MIX KEROSENE WITH DIESEL.
ung ibang nsbhan k nyam my byad swerte m at for free m nlman hehe c u s mcpagal, n plate no ng xuv m? jok pre
