Results 1 to 10 of 16
November 19th, 2007 11:55 AM #1
mga bossing..,
ive got a problem regarding sa transmission ng civic vti ko, kc habang tumatagal yung byahe pag umaapak ako ng todo sa accelerator nag vivibrate ung sa may shift area or transmission, pag overdrive naman bihira lang siya magkaganun.. di ko po alam problem.. naipasok na sa casa ng ate ko kaso di tumagal ganun pa din e.
any recommended shops na gumagawa ng a/t transmission na reliable at magaling gumawa?
THANKS.
November 19th, 2007 01:17 PM #2
pag d3 gamit mo nag vvibrate din ba? sa kin kasi minsan lang parang kapos lang ng gas pag accelerate kna nawawala pero pag d3 gamit ko inde nman...
November 19th, 2007 05:03 PM #3
ganyan din sa akin sir, anu ba ang ginawa ng casa nung una? wala ba yan warranty since sila naman ang gumawa? hinde ko pa kasi na experience yan sa oto ko. jerking lang pag kambyo N-R and P-R
November 19th, 2007 06:19 PM #4
November 19th, 2007 06:23 PM #5
November 20th, 2007 02:58 PM #6
nung tinanong ko dati sa mekaniko ko..nid daw na overhaul ang transmission...kaso medyo mabigat ang gastos...abutin ng 16K
November 20th, 2007 08:22 PM #7
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 20th, 2007 11:29 PM #8there should be no difference in vibration when in OD or when wala. baka naman it's an engine vibration or a problem with the suspension rather than a problem with the transmission.
- May 2007
- 50
November 21st, 2007 09:00 AM #9Medyo OT: Paano naman po pag M/T with the same problems-vibration sa stick lalo na sa first gear? Salamat po
November 21st, 2007 02:25 PM #10
pag D4 frequent vibration, D3 not quite, pag OD(overdrive) bihirang bihira, all occured kapag tumatagal na tumatakbo yung oto. pero pag simula wala siya. i think its on the transmission sir kc yung panel sa shift and the shift stick itself nagvivibrate wala masyado sa harap at sa dashboard..
nagseservice po ba kayo ng ganitong problems? how much estimate nyo sir?
thanks!
