Results 1 to 4 of 4
    Aug 2008
    Gandang araw mga sir. ask ko lang kung normal ba na ang RPM ko ay nasa 3,200-3,500 pag ang takbo ko ay 100? at saka pala pag naka stop ako at inapakan ko ang gas para yatang magbagal syang mag pick up. umaabot muna ako ng 2000 rpm bago ko maramdaman na umandar sya, lalo na kung naka A/C. gusto ko munag subukan na mag drain ng ATF at palitan ang filter baka sakaling magbago. Any suggestions from all of you na may nalalaman sa transmissions it will be a big help for me. at saka po pala, madali po bang maglinis ng servo? kasi pag naka AC ako. bumababa ang idle na parang mamatay. pinalinis ko na ito noon pero ganun pa rin at di nagbago. gusto kong ako na ang maglinis baka di nila nalinis masyado dahil sandali lang nila nilinis. at sabi pa sa akin ng mekanik baka daw sa computer na ang problem kaya di mag idle ng maganda.tulong naman please. thanks
    Aug 2004
    100kph at 3,200-3,500??? Most like your overdrive is not engaging. Are you sure your OD is on? Kaya ng Lancer AT ko 100 at around 2500.
    Kayang mag-DIY change ATF and filter medyo madugo nga lang. AFAIK same tranny tayo so most likely internal filter yan. Drain old ATF by removing the two drain plugs, remove 12(?) bolts holding ATF pan in place, remove 4 bolts holding filter, attach new filter, clean ATF pan and magnets, replace ATF pan, refill with around 5-7 liters ATF. Make sure walang leaks.
    As for your servo baka mali lang ang adjustment for aircon idling. When my mechanic (search for Raymond Sarol somewhere on tsikot) cleaned my servo iba ang idling adjustment for no aircon and with aircon.
    HTH
    May 2007
    Your vehicle is fuel injected(not a carb) and the most likley start would be to look at the IAC(idle air control)valve for the screeen to be partially clogged. This will not allow the valve to properly adjust your idle quick enough when the load of the a/c is applied.Assuming you did not recently overcharge your a/c????? This would be where I would start. As long as your check eng. light is not on there is nothing casa or any computer can do for you! This valve is mounted on the front upper side of the upper intake(two 12mm bolts and it comes off). Has a small black plastic cyl as part of the valve and has a small screen about half the size of a dime-use throttle body cleaner to clean screen and entire inside of valve. GOOD LUCK!
    Aug 2008
    Wow! thanks for the reply. ang bilis ng action. sirs john and dreamer. thanks a lot. enlightenment sa akin ito. sir john naka on lagi ang OD ko. hindi pala talaga normal ang 3500 rpm according to your lancer it can run pala ng 2500rpm per 100kph. I will try to change my ATF as you advised and check if it will improve sana ito lang ang dahilan. the last time i checked the ATF medyo foamy siya, a sign of overfilled.kaya lang di rin ako sure kung yun nga ang nagiging cause. ang alala ko lang since na di nag aactivate ang OD, baka naman computer or electronic problem na din ito.wag naman sana. at try ko din na pacheck ang AC ko baka naman overloaded ng freon baka nagkakaganito. thanks sa mga payo sir! kahit papaano nakahinga ako ng konti.mejo alam ko na kung papaano. thanks uli.
1994 galant A/T question
