my mechanic brought down the A/T tranny of my flooded 09' altis for flushing. after putting it back, i started the car but couldn't shift it into drive.what could be the cause of this?
is the shift interlock circuit located under the a/t shift console?(not sure if that's what you call it)+1 on the fuse, my fuse block is malfunctioning so that could be the problem as well.thanks sir bambino!
Simply put, the brake pedal switch (when you step on the brakes) powers up a solenoid near the shift lever, which in turn releases the lock, allowing you to shift it out of Park. Do your brake lights work? Do you hear a "click" or "jug" near the shift lever whenever you step on the brakes?
Since the car was flooded, the solenoid may be stuck in the locked position. Try to check if there's 12V DC going to the solenoid when you step on the brakes and go from there.
