Results 1 to 9 of 9
    Jun 2007
    guys, recently, my 2000 honda civic has been recommended by the casa during check-up that the clutch master has leak, and needs to be replaced. the slave was not mentioned that it has leak too, but was also recommended for replacement. i was also advised that the d/shaft oil seals need to be replaced.
    1) any reason why these parts need to be replaced? due to normal wear and tear? bad driving habits?
    2) how to verify by myself? any shop/s recommended for 2nd opinions?
    3) additional tips if this problem really occurs (replace whole clutch assembly, etc.?)
    4) what parts to buy, go for the casa, or just at some reputable shops?
    5) dangers/risks when these parts are not replaced the soonest possible time?
    thanks in advance for your help guys
    Jun 2007
    up ko lang
    Jul 2003
    1. clutch master and slave repair kit if available is a much cheaper alternative than replacing the complete assemblies.
    2. d/shaft oil seal, is this drive shaft boot? they get torn from normal wear and tear and can be replaced individually.
    Jun 2007
    thanks sir tip. any recommended shop/s that can do the quality repair?
    Jun 2007
    Jul 2010
    are you afraid of the casa?
    Hindi naman ata masyadong maselan and master and slave replacement.
    A regular service center can fix it.
Clutch master/slave and d/shaft oil seals (l & r) replacement
