Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Apr 2010
    I just purchased a pre-selling townhouse and according to the engineer, the size of the parking space is 5.4 meters width x 4.9 meters length with walls on both sides. Any idea if its still spacious getting in or out of the vehicle? Is there enough space to walk around the car without scratching/denting the car? Here's the width of the car:Montero (1815mm width) and altis (1760mm width).
    Thanks in advance
    what is the land area ng townhouse and saan location?
    kasi mga gumagawa ng ganyan ngayon eh walang paltos masikip parking.
    Tight but yes. Its just like having 2 parking slots.
    Apr 2010
    around 96sq.m lot area. Kaingin QC. So masikip nga?
    Apr 2010
    based kasi sa computation ko, still have 2 ft allowance both sides and middle. just not sure lang if included sa size yung side mirror.
    Quote Originally Posted by tribal View Post
    Thanks in advance
    A minimum size of parking slot (perpendicular) is 2.5meters (wide) by 5meters (length) as per latest (most current) building code requirement. But keep in mind, that 2.5 was for parking slots meant ideally only for public parking (meaning no walls to each side).
    It is a "tight fit" but definitely do-able.
    Can you go around both cars? Nope! Hehe! You will most likely park one car close to the right wall and the other to the left wall, so that you would have ample space in the middle as a "walkway" to get in and out of your house to the gate, without needing to drive one of the cars out.
    So if one car is already parked inside the house, you'll have to disembark your passengers first outside the house before backing or driving in the gate (depending on which side is sticking to the wall for the car and which slot you are parking into).
    NOTE: please keep in mind as well, he mentioned the 5.4m width is "with walls". Therefore, it is not clear width/clearance. You deduct at least 8" thickness on each side or roughly 200mm, assuming plastering goes well and hindi sablay yung hulog/buntis yung paggawa. That leaves you with a max 5meters clear width, not 5.4meters. Hope that helps. Hindi ko din alam kung san napunta ngayon yung lapad ng poste. Pinakain ba nila sa kapal lang ng hollow blocks na may palitada? How about yung poste nung gate mismo?
    Its as if you parked at the mall.
    Apr 2010
    Quote Originally Posted by 17Sphynx17 View Post
    Thanks a lot. I think best way is to go to the site and measure it by myself to confirm if its 5mt or 5.4mt. by the way, there is no gate sa unit. so basically 3 sides wall lang then open yung entrance
    Got it.
    Remember when measuring, measure near floor, middle and around your head (to approximate kung walang reduction sa width). Ideally plumb bob kung asa hulog, or spirit level to check alignment.
    Kung clear sana yung 5.4m width, okay na yu, giving you a 2.7m parking slot per vehicle. =)
    Apr 2010
    Got it.
    thanks sa info. will confirm it on sunday nalang.
    tingnan mo pa yung sampayan kung gaano kalaki kasi eventually yung parkingan mo portion nyan magiging laundry area. Sawang-sawa na ako kakaikot ng townhouse dito true qc kahit village townhouse pa gawa ni ayala yung sa likod ng st lukes eh sikip ng parking. Naging paradahan con sampayan. Amoy downy!!!!
    Ang malalawak yung naitayo nung 90s.
    Engot mga developer ngayon kwarta muna.
    Apr 2010
    yeah yun nga din na napansin ko.may laundry area sya pero ang liit ng space para gawin sampayan, buti may balcony sya na medyo mahaba pero nasa second floor. so after laba, akyat nalang para isampay hehe
    Thanks in advance
    just looking at the figures, i believe that is comfortably adequate, for one car.
    but it really depends on... how fat are you?
    serious!
    ganito gawin ninyo.
    set up an imaginary bakuran around your car, using the aforementioned dimensions. then see if you can get in and out of the car comfortably enough, without the open door going over the mark.
    this is what you're gonna do for the rest of your life in that dwelling.
    if you can get a second parking slot, get it, po.
    "hindi kayo magsisisi."
    a five meter wide space for garaging two cars?
    that would be difficult. not impossible, but difficult.
    na-spoiled kasi ako ng garahe namin.
    Apr 2010
    Actual width lang ay 5.25 meters
    luxurious, if only one car.
    more difficult, if two cars.
    i would park the two cars very close to their respective walls. also, one car would be facing the wall, the other car, opposite direction, to maximize door-opening allowance... to ensure that their drivers can swing open the doors wider out and get in or out, easier.
    but passengers from the other side of the car, will have to wait for the car to exit the parking slot, to get in.
    Aug 2008
    Kasya sir,sa akin nga 3.5m width. Hindi nga lang mafully open Yun door hehehe.
    Sent from my Mi A2 using Tapatalk
    Apr 2010
    yep luxurious for one car. hehe..
    (i would park the two cars very close to their respective walls.) Not possible since yung main door ng bahay is nasa left side. so if sinagad ko sa wall mahirap din pumasok sa house.
    Jul 2013
    naalala ko nung pinarenovate ng mommy ko yung house nya... kasya nga car sa bagong garage... di naman mabuksan yung Pinto
    one sometimes wonders who decided how to make the garage.. forgetting that cars have doors.
    not-wide-enough.. not-long-enough..
    Apr 2010
    nyahahahaha...baka kelangan baba muna siya then itulak papasok ng garage
two car garage parking
