Results 1 to 6 of 6
    Feb 2014
    not a trailer, right?
    Jan 2009
    You're technically towing another vehicle, not a trailer. I don't see any issue with it. Although, it might be prudent to install a red auxiliary tail or marker light and/or some high-visibility device/EWD on the bike's rear.
    wala ba lower speed limit pag towing another vehicle or trailer?
    Feb 2014
    it's a nice workaround and alternative to using a trailer, right? coz trailers have to be registered, must have chassis#, plate, and all that ek ek. otherwise you're susceptible to kotong
    afaik towing another vehicle is perfectly legal
    sounds like a plan
    Feb 2014
    i'm not sure. but i've read that you can't use NLEX while towing another vehicle
    if i bump into it, i can argue in court, that it lacked warning lights. as oj says, you'll need warning lights behind the bike.
    errr... do the yellow restraining ropes have to have a minimum tensile strength requirement, to be used as such? i do not know.
What the legality of doing this? This is technically not a trailer...
