Results 1 to 10 of 19
- Feb 2013
- 10
February 22nd, 2013 07:43 PM #1hello everyone,tanong ko lang po sa mga matatagal na driver at automatic ang gamit..pag po ba ng start kayo ng car inaapakan po ba muna ang brake bago mg starttng engine.or pede start na lang engine ng hindi inaapakan ang brake...masisira po ba sasakyan pag di muna inapakan brake?
confusing lang po..im new driver...thanks
- Nov 2009
- 3,509
February 22nd, 2013 08:19 PM #2New AT cars won't crank the starter if you dont step on the brakes, this has been the standard safety feature and the best practice to do for starting an AT.
Some MT''s nowadays use similar safety feature, u cant crank the starter if you dont step on the clutch.
February 22nd, 2013 08:36 PM #3
my 2010 car starts even w/out stepping on the brakes as long as the gear is in P (park) position.
February 22nd, 2013 08:39 PM #4
matagal na yan sa M/T yun mga korean cars circa mga kia pride, ganyan na eh...tinatapakan muna clutch before mag start...
but to answer TS's question, its doesnt make any difference...first hinde nga mag start pag wala sa P yun shifter and hinde mo rin naman maaalis yun susi pag wala sa P, so in essence automatic nasa P before mo ma starrt
- Aug 2012
- 2,767
February 22nd, 2013 08:55 PM #5depende siguro sa design ng sasakyan. for the 2013 Toyota RAV4, eto nakalagay sa owner's manual.
Starting the engine
1. Check that the parking brake is set.
2. Check that the shift lever is set in P.
3. Firmly depress the brake pedal.
4. Turn the engine switch to the “START” position to start the engine.
pero sa Toyota Revo namin, i can start the engine without stepping on the brake pedal just as long as the shift lever is in P or N.
- Nov 2009
- 3,509
February 22nd, 2013 09:15 PM #6Depende talaga sa make ng car. Pero standard safety feature is to step on the brakes to assure the tranny is disconnected and wheels are braked - solution ng manufacturers sa mga makakalimutin.
Kahit driving school yan din ang tinuturo, limutan na ang lahat wag lang ang preno when starting and stopping the car.
Tsikot Member Rank 4
- 2,719
February 22nd, 2013 09:39 PM #7The technical term is "safety interlock", wherein a certain process will not proceed until some safety features are established.
February 22nd, 2013 11:05 PM #8
Most cars will start when the car is shifted in either Park or Neutral only.
February 22nd, 2013 11:10 PM #9
Pag de susi, start na agad basta nsa Park position. Pero pag 'Push Start' need mo tapak sa brake.
February 22nd, 2013 11:29 PM #10
Tama lahat ang sagot ninyo,- depende iyan sa sasakyan....
TS - whatever works for you,- there you go....
18.2K:soccer2:
Medyo wimpy nga lang yung busina, masikip (same space as a Kia Pride), tinny audio, and, as...
VinFast VF 3
