Page 92 of 257 FirstFirst ... 4282888990919293949596102142192 ... LastLast
Results 911 to 920 of 2562
    Oct 2014
    #911
    [QUOTE=ned27;2501752may iba ako nakikita sa parking sa makati, ibang bolts ang ginamit, don't know why.[/QUOTE]
    bolts provided by LTO will "permanently" install the plates. so, what if kelangan tanggalin ang plates in case of repair sa portion na pinagkabitan?
    Oct 2014
    #912
    sino magaling mambutas dito? may papabutasan ako! hehehe
    kidding aside, di ko pa din nakakabit yung sticker kasi naka full tint ako. tsaka yung bolts, di ko pa din naaayos.
    wag naman sana mahuli hehehe
    Apr 2008
    #913
    *JJ All Day: For me I don't think they are permanent. Pwede padin siyang matanggal pero sobrang magkaka gasgas ung plate and pagta tiyagaan mo. Kasi when I installed mine, naputol ung head even before it got tightened so I used a pair of pliers to tighten it. The plate got some minute scratches and the edges of the bolt became rough after. Doon ko nakita na possible padin siyang matanggal, mahirap nga lang.
    May 2013
    #914
    Question mga ka tsikot, pede ba ko magrequest ng new sticker sa LTO? Mali kasi yun kabit ng sticker, nasa ilalim kasi ng tint, gusto ko sana ayusin. Yun sticker november ko nakuha.
    May 2013
    #915
    May nakita ako sa labas nya dinikit ang 3rd plate sticker. Kinapa ko eh. I dont know how he did it. Di ko na tinitigan pa lalo kasi late i noticed may tao pala sa loob Hula ko dinikit muna nya ang sticker sa clear plastic then adhesive sa likod
    Sep 2014
    #916
    kapag panahon nang dapat palitan, mas madali na, dahil yung lumang nakasalpak ang magiging guide kung gaano kalaki ang bubutasin.
    yup, that's the plan. looking at the sticker nga, mukhang yung years lang ang kailangang palitan. iwan na yung part na may plate number.
    so, pag palitan na, tsaka ko na lang bubutasin yung tint, with the sticker as a guide.
    Oct 2014
    #917
    Teka lang, pano ba magbutas ng TINT? using cutter??
    Nov 2014
    #918
    Quote Originally Posted by JJ All Day View Post
    cutter, ballpen/pencil, ruler
    1. i-trace mo ung size ng sticker sa tint using pencil/ballpen pero wag masyado madiin..
    if you want pwede ka din mag gupit ng small tapes para i-tape mo ung sticker - para hindi nakaka-ngalay hawakan ung sticker against sa windshield.
    2. pag natrace mo na, use ruler at cutter to cut. light lang - ramdam mo naman kapag smooth na ung run ng blade, ok na na-cut na yan.. wag gamitin ung sticker as guide kpag nag cutter ka, kasi baka macut mo sticker mo.
    3. remove ung tint slowly, careful ka sa edges para ung sakto.
    4. if may natirang adhesive, use alcohol para alisin, then clean mo na din if may traces ng pencil.
    5. dikit na sticker - double check before sticking baka baliktad! hehehe
    Nov 2014
    #919
    Quote Originally Posted by arayes View Post
    pag ako kapitbahay niya at mayabang siya.. aalisin ko ung sticker niya.. hahaha
    Aug 2012
    #920
    Need ba i-cut ang tint for windshield sticker kahit light tint ang gamit, example V-Kool VK40?
No PLATE No TRAVEL Policy?
