Results 1 to 9 of 9
- May 2004
- 102
March 1st, 2007 08:53 AM #1have you seen this fence concrete na ini-istack along NLEX?? anong comp. kya nag bebenta ng ganito? or similar.
Pang bakod na walang hassle, easy and cost effective??
March 1st, 2007 08:58 AM #2
Aling fence po? Yung center divider or iba?
March 1st, 2007 09:15 AM #3
yung sa gilid ng NLEX yan, yung pinaka boundary. baka gawa lang yan ng contructor ng NLEX, yung Leighton yata.
- May 2004
- 102
March 2nd, 2007 08:16 AM #4ahh ganun ba? wala bang similar na ready made na magandang pang bakod na concrete?
- 10,620
September 22nd, 2014 12:27 PM #7
reviving this thread. I am trying to look for a contractor to do the fencing of my parent's lot. front fence lang muna. around 100meters yung length.
i am looking at pre-fab fence na tulad nung sa NLEX para maganda na and simple lang. i am not sure about the cost if mas mura ba kesa traditional hallow block fence.
any suggestions sa contractor/fence supplier? yung Vazbuilt ang bagal daw ang magulo kausap based sa nabasa ko sa ibang forum. Not sure kung meron pang mas ok. or should we go with the traditional hallow block fence nalang?
also, pag papagawa ng fence, kailangan na ba ng building permit?
- Mar 2009
- 823
September 22nd, 2014 12:33 PM #8for long lasting, hollow block would be good- precast would depend on the post structure.
re permit - yes, you will need a "fencing permit"/ vis a vis construction permit - that's in case if the village admin is strict
yes, vasquez built and other simillar firm/company is a hassle to deal with- my suggestion is to hire a local(small firm) local hardwares usually knows a few and some hardware has it's own construction side line(hence alam mo di ka kukulangin ng material)Last edited by victorevolution; September 22nd, 2014 at 12:36 PM.
- Jun 2006
- 1,139
September 22nd, 2014 03:48 PM #9I saw that fence at vazbuilt, pre fab na sya pag deliver syo. All u need to do is setup the post. Me susundin daw na plan for exact fit.
Sa kwenta ko nung nagpa fencing ako,same lang gastos sa material compared sa 4in hollow block. Except with prefab, labor is less and smooth na ang finishing.
Mahal ang palitada ng hollow block.
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
