Page 36 of 41 FirstFirst ... 26323334353637383940 ... LastLast
Results 701 to 720 of 1667
    Yan nga yung sinasabi ko pag di sila aware sa mga radar dun habang mabilis ang takbo nila.
    Pa northbound yung punta?
    Yup. Usual radar at Luisita.
    Dec 2017
    I've heard that there are devices that can detect speed traps. I wonder how much is it and where can you buy one.
    The gps of the latest avt headunits found in many ppvs has a feature that can detect those speed radars when you're travelling there. It will warn you, saying 'there is a speed camera'.
    2079 binayaran ko sakin, bakit may discount kayo?
    Sent from my SM-C900F using Tapatalk
    Paid the same when I was tagged at SCTEX within Tarlac area.
    Kulit nung Wildtrak kanina sa SCTEX. For about 15 minutes naka-tail lang siya sakin while I was in cruise control at 120 kph. Eh mukhang nangati humataw, so nagovertake. Ayun, huli sa tollgate. [emoji23]
    Baka may tawag na, tawag ng kalikasan. Hehehe
    Nov 2017
    Sinusubukan yung car mo bro [emoji1]
    Apr 2012
    Quote Originally Posted by maxpedition View Post
    maybe the other way around, sinusubukan pasensiya ni bro jut kung kakagat at makipag-karera ayun huli siya
    Hindi ba parang kabayo na iyan (matalbog) at that speed?
    Hindi bro. Had a Ranger too - felt very planted all the way to its 175 kph top speed. [emoji106]
    Thanks for the info, bro... Tough luck for the impatient and aggressive driver... 😉😉😊
    Sep 2016
    120 kph ba max speed na hindi huhulihin?
    Sent from my ONEPLUS A3003 using Tapatalk
    Quote Originally Posted by Danilog View Post
    It seems to be the norm among those who frequent NLEX/SCTEX/TPLEX. Do anything faster and you might get tagged then apprehended at the toll gates.
    Alam ako up to 110kph pero siguro sagad na dun yung 120kph. Huhulihin na pag nakitang mas mataas pa dun yung takbo.
    Jan 2018
    Is that 120 kph on the speedometer or on a gps app? Minsan magkaiba reading sa akin
    Quote Originally Posted by SpinCycle View Post
    Speedometers are not 100% accurate. They may be off by around 5%.
    Just doing 120kmh on the speedometer is fine on NLEX/SCTEX/TPLEX.
    Jun 2015
    Depends on what size of tires the speedometer was calibrated to. Strangely, using the stock tires doesn't guarantee accuracy either.
    Depends also on the tires you are running with.
    If you replace the stock tires with tires that have different size, diameter, specs, etc. then that will have influence in the reading of your actual speed on a highway.
    By default, speedometer readings are about 5% faster than your true GPS speed if you have stock tires.
    My 120 kph speedometer reading is 114 kph on my GPS. Using 225/40R18 tires (roughly the same circumference as the stock 215/55R16).
    If you want your GPS and speedometer readings to match, use bigger tires.
    same here. my speedometer reading of 120kph is 114kph on gps using stock 265/50r20s. when i changed to 275/55r20s the speedometer and gps readings are almost exactly the same. so i just set the cruise control to 114kph para safe sa huli.
    Was driving down NLEX soutbound with Waze on earlier - the pole-mounted cameras are as follows:
    1. Across Petron Plaridel (before Sta. Rita exit)
    2. After Sta. Rita exit, before Shell of Asia
    3. After Shell of Asia, before Petron Bocaue
    4. After Bocaue Toll Plaza
    Have a safe drive!
    Sep 2006
    Have a safe drive!
    Can someone post a pic so I'd know how these look like?
NLEX, SCTEX, Over-Speeding, Speed-Radar  [MERGED Threads]
