Page 2 of 2 FirstFirst 12
Results 21 to 40 of 60
    up............
    Feb 2009
    [SIZE=3]JSPYDREJ,
    [SIZE=4]Do not grab the steering wheel from the inside, as this can be very dangerous. You won’t be able to correct the wheel’s position in case something unanticipated happens (like a vehicle suddenly appearing in the direction you’re turning towards).[/SIZE]
    [SIZE=4]There are different ways to steer the steering wheel, and this includes the following:[/SIZE]
    [SIZE=4]* Palming - A one-hand steering technique where you press your left palm (the hand not doing the shifting) onto the wheel to turn it round and round.
    * Hand over hand - A two-handed technique where one hand may cross over the other hand when needed.
    * Shuffle steering - Considered a safer way of operating the steering wheel. This entails your left hand staying on the left side of the wheel, and the right hand on the right side.[/SIZE]
    [SIZE=4]The best, by far, in my opinion is shuffle steering. [/SIZE]
    [SIZE=4]Your left hand always stays on the left half of the wheel. Your right hand always stays on the right half of the wheel. So, the highest your hands can go is where both hands are at 12 o’clock (your hands touch their index fingers together). The lowest both hands can go is 6 o’clock (where your hands touch their pinkies together).[/SIZE]
    [SIZE=4]When you turn right, it is because your right hand is pulling down on the wheel. When you turn left, it is because your left hand is pulling down on the wheel. This pulling down comes from your back muscles, and is therefore very powerful. So, if you’re going to take a right turn, slide your right hand up the wheel, grip, and then start pulling down. If you “run out of wheel” (the right hand hit edge of its legal range of motion [6 o'clock]), the left hand can grab the wheel to keep it from turning, and you slide the right hand up, grab the wheel again, relax the left, and then continue pulling down with the right.[/SIZE]
    [SIZE=4]Bobby Ore has developed the ultimate steering technique, a variation of shuffle steering. In short, he adds one constraint, both hands must always be at the same height. In other words, here are some “legal” positions (given the left and then the right hand):[/SIZE]
    [SIZE=4]* 12 and 12 (index fingers touching)
    * 11 and 1
    * 10 and 2
    * 9 and 3
    * 8 and 4 (the suggested default grip)
    * 7 and 5
    * 6 and 6 (pinky fingers touching)[/SIZE]
    [SIZE=4]Note that if you know where one hand is, you know where the other hand is.[/SIZE]
    [SIZE=4]So think of this more like raising and lowering your hands, where they are at the same height. The only exception to this same height rule would be when you are adjusting the height of your hands without turning the wheel because you feel like doing so.[/SIZE]
    [SIZE=4]Shuffle steering is not only safe. It can also lessen the likelihood of getting soreness in your chest muscles and biceps, because it’s the stronger tricep and back muscles you’re using. This is especially useful if you’re operating a car [/SIZE][SIZE=4]without power steering.[/SIZE]
    </SPAN>[/SIZE]
    Feb 2009
    [SIZE=3]Do not grab the steering wheel[/SIZE][SIZE=3] from the inside, as this can be very dangerous. You won’t be able to correct the wheel’s position in case something unanticipated happens (like a vehicle suddenly appearing in the direction you’re turning towards).[/SIZE]
    [SIZE=3]There are different ways to steer the steering wheel, and this includes the following:[/SIZE]
    [SIZE=3]* Palming - A one-hand steering technique where you press your left palm (the hand not doing the shifting) onto the wheel to turn it round and round.
    [SIZE=3]The best, by far, in my opinion is shuffle steering. [/SIZE]
    [SIZE=3]Your left hand always stays on the left half of the wheel. Your right hand always stays on the right half of the wheel. So, the highest your hands can go is where both hands are at 12 o’clock (your hands touch their index fingers together). The lowest both hands can go is 6 o’clock (where your hands touch their pinkies together).[/SIZE]
    [SIZE=3]When you turn right, it is because your right hand is pulling down on the wheel. When you turn left, it is because your left hand is pulling down on the wheel. This pulling down comes from your back muscles, and is therefore very powerful. So, if you’re going to take a right turn, slide your right hand up the wheel, grip, and then start pulling down. If you “run out of wheel” (the right hand hit edge of its legal range of motion [6 o'clock]), the left hand can grab the wheel to keep it from turning, and you slide the right hand up, grab the wheel again, relax the left, and then continue pulling down with the right. B[/SIZE][SIZE=3]oth hands must always be at the same height. In other words, here are some “legal” positions (given the left and then the right hand):[/SIZE]
    [SIZE=3]* 12 and 12 (index fingers touching)
    * 11 and 1
    * 10 and 2
    * 9 and 3
    * 7 and 5
    [SIZE=3]Note that if you know where one hand is, you know where the other hand is.[/SIZE]
    [SIZE=3]So think of this more like raising and lowering your hands, where they are at the same height. The only exception to this same height rule would be when you are adjusting the height of your hands without turning the wheel because you feel like doing so.[/SIZE]
    [SIZE=3]Shuffle steering is not only safe. It can also lessen the likelihood of getting soreness in your chest muscles and biceps, because it’s the stronger tricep and back muscles you’re using. This is especially useful if you’re operating a car[/SIZE][SIZE=3] without power steering.[/SIZE]
    </SPAN>
    Quote Originally Posted by jspydrej View Post
    boss tanong ko lang paano po talaga ang proper na
    paghawak ng manibela(proper position na kamay) kapag
    power steering or kahit hindi power steering, 9oclock
    - 3oclock or 2oclock - 10oclock, meron naman akong
    nakikitang nagdridrive isang kamay lang ang gamit
    kaliwang kamay lang ang gamit ok lang po ba yun na
    isang kamay lang ang gamit. tips naman po dyan...
    kung san ka komportable, pero suggestion nila sa may mga airbags eh sa baba, 4oclock and 8oclock, para pag nag lumabas yung airbag pababa lang yung kamay mo at makaiwas sa injury.
    Pag sa intersection naman from stop light halimbawa
    mag go go na at kakaliwa na or kakanan po at medyo
    marami kang mga kasabay na jeep na umaarangkada rin or
    may katabi kang jeep sa side mo ano po ba ang mabibigay
    nyo sa akin na tips or guide. kasi muntikan na daw ako
    bumangga sabi ng tito ko sa jeep kung hindi ko daw
    nakabig yung manibela pakaliwa kasi nasa kanan kasi
    yung jeep, nauna po sya sa akin tpos kung hindi naman
    daw baka sa Concrete Barriers naman ako bumangga
    medyo mabilis kasi yung pagliko ko sa intersection e
    dyan sa intersection sa Taytay Rizal bale nag highway
    kami galing kasi kami ng Morong Rizal.
    hirap to pre, this is something you learn thru experience, at yung tantsahan sa kotse. paganda nito eh gumamit ka ng mga monoblock na upuan sa may inyo, i ayos mo sya ng ng kasya lang kotse mo, pakanan or pakaliwa, dito ka mag praktis, para makuha mo mo yung tantsa sa sasakyan mo.
    Pag sa zigzag na daan naman at pataas or pababa at
    matarik ang daan bigyan nyo rin po ako ng tips like
    dun sa antipolo or tanay. usually marami po dun
    naaaksidente kung hindi bumabangga pede ring mahulog
    sa bangil.
    konti pa lang experience ko sa ganito, sa tagaytay pa lang, ang tanging tip ko lang eh slow down at dont overtake, kung pababa naman eh alalay lagi sa brake pati na handbrake just incase.
    tips na rin po na proper left turn or right turn
    tips para makaiwas aksidente...
    sensya na po bago lang po ako nag dridrive...
    thanks po...(",)
    driving school can help you alot pero kung di mo kaya, sa inyo ka muna paikot ikot.
    Tips naman po kapag nabangga ano po ba dapat ang gagawin, kapag nakabangga ka ng sasakyan or ikaw naman ang nabangga or nagitgit ka. ano po ang nararapat na gawin? thanks
    Apr 2009
    unang-una, wag gagalawin kahit ano. (kahit porma ng manibela)
    ikaw ang nakabangga - mag-sorry ng maayos, tapos estimate mo kung mga magkano ang gagastusin. as much as possible, wag nang maghintay ng pulis/enforcer since lalo kang madidiin, pera pera lang naman yan.
    ikaw ang nabangga - tingnan ang damage sa iyo, estimate ka, singilin mo ayon sa estimate mo, kung ayaw, nakabubuting tumawag na ng pulis/enforcer para maayos ito.
    e kung tinakbuhan ka naman ng nakabangga sayo ano naman po ang nararapat mong gawin. thanks po
    take note of the license plate file ka ng blotter sa pulis tapos contact your insurance company
advice naman po newbie po ako sa pagdridrive ng kotse.
