greetings to all the bigbody owners, engine swapping? i have a 2e engine, mag fifit ba ung blacktop engine? anu anu mga babaguhin kung sakasakali? mga mgkanu kaya aabutin kasama labor? tips nmn jan..thanks bros!![]()
I myself own a somehow modified bigbody corolla.
Re: engine swapping
Kakasya ba ang blacktop?
Definitely.
There are other options you could choose from aside from the blacktop.
1. 4AGE 16V HH ( High-Horse ; power is low-mid range. top-end power somehow lacks. economical. )
2. 4AGE 20V Silvertop ( power is mostly at high mid-high range. power at crank is 158HP. depends on the condition of the engine. kung tono na ba )
3. 4AGE 20V Blacktop ( power is mostly at mid-high range. power at crank is 163HP. fuel efficiency is acceptable for the power given. 7km/L on normal conditions. Can go below 5km/L if the engine is not in good condition )
4. 3SGE Beams 2.0L VVTi ( spectacular power, rare engine )
5. 4EFTE 1.3L Turbo ( economical. easy to tune. pretty fast for a 1.3L. power at crank is around 130HP stock power is mostly at mid range )
*there's a long list of engines available for the corolla, wala lang akong time isulat lahat. lol.
Magkano for the blacktop = 70-80k
Magkano for the silvertop = 50k sa Evangelista
Magkano for the 4EFTE = 70k with FMIC
Ano ang babaguhin, usually engine support yung aircon and yung wirings definitely
The said prices eh kabit pa lang. Pag-tono, pag-mods at kung ano ano pa ay wala pa dun.
Before you entertain engine swapping make sure your pockets are deep, meaning may budget ka for lets say mga 120k atleast. Hirap na mabitin. Mababadtrip ka lang.
a have a 2e carb engine, wala aq masabi sa performance ng makina, smooth at ok ang takbo nya AT THIS TIME, gusto ko lng mgkaron ng idea in case pgdating ng panahong mg engine swap din aq, regarding sa engine ko mabilis nga at smooth ang takbo lalo na kung patay ang aircon, ang iniisip ko lng ung sa carburador, may mga hose na rin kasi na di na gumagana, dq ko rin masabi kung anu ung porpose ng hose na un eh, pero ok nmn car performance,nabili ko kasi ng second hand ung car kaya wala na rin aq idea sa history ng car,tanong ko lng ok lng ba na hayaan ko na lng na ganun na ung ibang hoses patay na? kasi ok nmn tlg takbo eh wala nmn ako nakikitang problema,
Hindi ko alam kung ano yung hose na tinutukoy mo sir eh, pero nandyan siya for a reason. Hindi display lang, so andyan yan para paganahin ang isang bagay.
Stock pa ba yung 2E mo? Magpa-simul ka bro, alam ng mga carburetor shops yun. Tignan mo bibilis yung Corolla lalo.
mag pa simul ba? anu un bro? mas bibilis pa ba to? mas ok! kasi para sakin mabilis na xa eh, un nga lng pag naka aircon medyo bitin ang arangkada, ganun nmn ata tlg diba?, hindi rin kaya sa compressor ko un? kasi my nagsabi sakin ung compressor ko kaw e pang dual, ok lng ba un o nakaka apekto din un sa takbo ng otto lalo na pag gagamitin mo na, kaya nga minsan pag gamit ko otto mas gsto ko wala n lng aircon kasi ang tulin nya eh,,tnx bro!! bow ako!![]()
try mo sir ipabalik sa stock compressor kung my budget ka pampalit, kc ok din nman lumamig ang a/c ng toyota. bka ngpalit nga ng pang-dual na a/c compressor eh hindi nman match un condenser at evaporator.
mga paps ask ko lang last week short drive lang ako dala rolla gli matic ko biglang umusok ng puti at makapal sya ok naman ang takbo at walang overheat tapos pag umaga pag start mo walang usok pero pag uminit na ang makina ayan na ang usok at masakit sa ilong ang amoy ano kaya ang sira nito thanks in advance
Valave seal lang yan, usually pag nagpalit ka ng valve seal eh palit kana rin ng Head gasket kasi nga ioopen yung block mo, hence meron naman na hindi na inoopen yung head para hindi na magpalit ng gasket so sa head cover nalang yung open tapos dun papaloitan yung valve seal mo..miura lang valve seal, around 3h -4h yung replacement.
mga boss. pa advice lang. medyo nagrarattle na kasi yung corolla ko pag umaabot na sya ng mga 80kph. hindi ko na tuloy sya matodo masyado ng mga 100kph. maayos pa ba yon?
mga paps may magaling bang mechanic dito sa las pinas area ? yung lovelife 2e ng anak ko naghihingalo na ang carb hard starting sya at bumabagsak ang menor tapos ng i try ko takpan ng palm ko ang carn halos walang vaccum na humihigop nag start naman sya pero ang lakas sa gas di naman itoganito dati nung maayos pa ang carb nya palit carb na kaya or overhaul lang muna? tia drivesafe
Salamat dito TS at may ganitong thread. Actually natututo ako dito.
Bago lang ako sa car world! Kakabili ko lang last monday ng Corolla XL 2E 1996 Carb at naghahanap ako ng mga guide sa mga master dito. Di pa kasi malinaw sakin ang functions nito kahit marunong ako magdrive at konting maintenance. Sana may makatulong sa akin para mapatagal ko pa to ng at least 5 years.
Any tips po sa pagmaintain? I need checklists sana ng:
1. What to check and pano check ng tama.
2. Anong mga dapat palitan na hindi naman ako gagastos ng malaki.
Current problems ko are:
1. May tunog ako naririnig sa front-right ko na sabi nila rubber bushing daw sa sway bar (na-research ko din ito).
2. Pag start sa umaga (umulan), may tunog sa belts. Minsan sa fan din pero nawawala pag tumagal na.
3. di ko ma-identify kung ano yung fluid sa top right corner under the hood kasi parang below min na sya. ( i think break fluid yun)
4. Pag nagchange ako ng gears from 1st, 2nd to third at pababa, ang tigas nya pero minsan nachachambahan ko ng timing ng clutch. Pero madalas di gano makuha, minsan smooth naman. Kailangan ko pang itodo ang clutch, pero minsan din ayaw.
Pasensya na at mahaba at madami na ito. Gusto ko lang kasi matuto para iwas gastos at headache.
Salamat in advanced!
Hi guys may 2E engine kami sa Bigbody namin. Ano po kaya pwedeng gawin para may konting performance yung kotse. Thanks
Darkside ganyan din ang naging sakit ng sa akin gli pina check ko sa mekaniko dito sa kilalang mekaniko dito sa Talon 5 nahanap nya yung sakit pumapasok yung brake fluid papuntang makina kaya makapal na usok na puti sira na yung hyrovac mo sir pero mas maganda kung yun muna ang pa check mo. message mo lng ako kung gusto mo dalhin kita sa kilala kong mekaniko kilala dito yung mekaniko sa Marcos alvarez kahit yung chairman namin dito sa kanya nag papagawa kasi mahusay gumawa.
mga ka-tsikot, ano ba ang magandang shock absorber para sa big body?
Salamat sirs.
