Originally Posted by
jdloveme
hello! just got my new vios2010 from toyota last tuesday, one of the features daw of vios is you need to fully (as in dapat lagpak sa floor) step on clutch to start the engine or it wont start at all.
as for its FC, im satisfied on my first 200 km... i computed that i run 18km/l on highway driving....
dati kc my ride is carburator type.
this is what i wanna ask other vios owner:
1. ganun ba talaga. on neutral, after you press and let go the accelarator parang late matapos yung revolution. may LAG ata...
2. since nasanay ako sa dati kong car na marinig mo if hihingi yung engine ng accel... sa vios dont you encounter problems like namamatayan ng makina kc nabibitin yung apak sa accelarator?( sa primera )
3. and last, pag namatay ang makina, sometimes di gagana i restart. walang response kahit apakan yung clutch, it takes 2 to 4 atempts para magstart.... ( panay tuloy busina ng likod lalo na pag sa trapik)
hope you can add infos
thanks in advance!
1. Completely normal since the engine is direct injection na and not carburator type.
2. definitely the drive-by-wire system
3. two culprits are possible: ECU or your god forsaken floor matting. Baka masyado ka po nagpapanik kapag nabubusinahan ka na at hindi mo na pansin that your matting is getting in the way sa pag-apak ng clutch. Fully depressed kasi dapat yan. Here's what you can do, bombahin niyo po 3x ang clutch before starting your car again.
Sa ECU naman, theory ko lang ito pero maybe it needs time to restart itself.
