Page 1 of 2 12 LastLast
Results 1 to 20 of 60
    PMS- post here everything about your PMS...
    mine is schedule this week,my odometer is 20,410, pumunta ako sa toyota marikina last friday....re sched na lang kulang yung dala kung pera e,
    estimate P10,800.00 gastus papalitan na daw yung transmission fluid,wheel allignment,spark plugs, change oil (ordinary oil) etc..etc....wala pang palinis ng aircon yan ha...
    wow! ang mahal naman ata ser?
    kunin nyo yung mga tatrabahuhin then pagawa nyo na lang sa labas... para mas mura...saka napaka aga yata para palitan ang mga fluids nyo? i mean change oil ok yan every 5thou km sop yan pero at 20k? tranny fluid? unless maitim na talaga saka pa lang siguro...
    nangenge alam lang po hahahaha...
    Aug 2007
    mahal talaga... pwede bang hindi sundin lahat ng nakalagay sa PMS? kasi diyan lalo nasisira ang sasakyan kapag parati nagpapalit ng oils and fluids kahit hindi pa kelangan. Dapat sana change oil, oil filter, fuel filter, at air filter lang. Check lang muna yung trasmission oil, spark plug, at wheel alignment.
    dapat daw kasi pag 20k papalitan na yung tranny fluids,yung mga rebaba daw nun kasi hahalo na, hindi ko masyado naintindihan yung paliwanag nung service advisor,pero it's a must daw talaga yun
    hindi ba mavo-void yung 3 years na warranty pag hindi mo sinunod yung PMS thru casa...
    Oct 2007
    Try to seek opinions sa different casa.
    Kaso dito sa amin, we only have one casa.
    So, no choice...check ko na lang thru other companies with diesel counterparts.
    hehehe.
    Papabong it’s a must kung under warranty pa para di ma-void…ask mo lang kung pwedeng kaw na magdala ng mga parts to be replaced (atf, oil and filter, spark plugs etc) para makamura-mura ka at makapili ng brands… may mga casa namang pumapayag.
    Ayos ito Papabong. Sariling bahay.
    Anyway, I'm nearing 15K. Probably next month na ako sked. Add lang siguro ng oil then some tightening. Nag full synthetic kasi ako last 10K PMS.
    May 2007
    Quote Originally Posted by papabong View Post
    wala pong nakalagay sa manual natin na kailangang palitan yung transmission oil sa 20K... sa 40K PMS pa po usually nirerequire na palitan lahat ng fluids sa Innova natin at maging sa ibang Toyota cars... ang hirap minsan sa ibang mga service advisor... parang di nila alam sinasabi nila eh.
    Quote Originally Posted by liv View Post
    try ko na lang siguro sa ibang casa,
    re: ATF change oil... bro, try checking your manual. if my memory serves right it should be on the 40k PMS.
    Aug 2006
    AFAIK for Gas engine and Manual Transmission:
    Every 5K - change oil and oil filter.
    Every 10K - change spark plug
    Every 20K - change air filter
    Every 40K - change transmission and differential oil, change fuel filter, change brake pads if necessary.
    thanks mile2. After days of observation di na umiilaw yung malunction indicator. maybe my guess is yung bibile nga ko mamaya ng coolant. almost said na yung laman, mga 1 inch na lang yung nasa reservoir. im just wonderin.. i had my unit periodically maintained in casa. just last PMS 40k palit lahat ng fluid pero pagkakita ko sa reservoir ng ko last week halos wala laman. hay naku... kaya cguro di na umilaw tumataas yung level ng reservoir. my plan is to bring it to casa para sigurado.[/color]
    bakit kaya naubos? Ang alam ko long life yung coolant natin. Good nga ito for 150,000 KMs. Hmmm
    May 2008
    gudday papabong,
    new member po ako....
    katatapos ko lng mag pa maintenance ng 20t pms, sa TAI, last week.
    eto ginawa nila, change oil/replace oil filter, nag tune up, clean d brakes, tire rotation and wheel balancing. it took me 5 hours. no need to replace the ATF, sa 40t pms pa naka schedule ang replacement ng lahat ng fluids & filters. and it cost me around 6k something.
    Quote Originally Posted by torpeng_isnaber View Post
    gudday papabong,
    sir torpe...matic po ba yung ride nyo?
    Aug 2005
    Mga 2 weeks ago. Avanza J sa TAI
    almost 14K
    + change oil, synthetic, 3 liters
    + change oil filter
    + change spark plugs
    + change air filter
    + tire rotation
    + wheel balance
    + aircon maintenance <- 8K, 3 days
    Aug 2005
    gudday papabong,
    almost 14K
    + change oil filter
    + change air filter
    + tire rotation
    + wheel balance
    Dec 2009
    almost 14K
    + change oil filter
    + change air filter
    + tire rotation
    + wheel balance
    I am due for 25K periodic maintenance of my Innova. I am currently using regular oil, and having my oil changed every 5K. Would it be advisable to shift to fully synthetic oil? What are the advantages and benefits compared to orrdinary oil? Your inputs are highly appreciated. Thanks.
    Quote Originally Posted by byrontamayo View Post
    synthetic oil can give you longer change oil intervals plus the engine would run smoother...
    Change Oil (necessary):
    Mineral Oil - every 5k
    Synthetic - every 10k
    Dec 2009
    guys, pa-help naman. first time ko kasi magpapa-PMS. nakaka-1K na kasi yung car ko and it's brand new, automatic. kelangan ba magpaschedule ka muna ng PMS mo sa casa or pwede dumerecho na kaagad dun ng walang pasabi?
    mga how much kaya magagastos? sabi nung agent ko, magpa-change oil lang daw ako sa 1st PMS e.
(PMS) Periodic Maintenance Schedule
