1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
kotse. com/home/images/stories/news/toyota/2012/vios_trd/viostrs_main.jpg
may vios 1.5G TRD model na..:D
JUN high lift cams for 1NZ-FE
JUN AUTO - JUN HIGH LIFT CAMSHAFTS and Kit - TOYOTA 1NZ-FE
problem: vios veers to the right
ano pwede ko solution and saan meron magaling gumawa nito
ang gusto ko kasi sa mekaniko is iyong madami na experience na isa tingin pa lang alam na ang problema at solusyon at confident sya sa ginagawa nya
salamat
Check tire pressures.
Try swapping tires left to right.
Check the alignment.
Roads are usually inclined a bit to the right to help drain rainwater from the pavement.
http://i251.photobucket.com/albums/g...0918-00987.jpg
http://i251.photobucket.com/albums/g...0918-00986.jpg
http://i251.photobucket.com/albums/g...0918-00988.jpg
kinakalawang na pre.. parang lumang luma na tuloy...
I don't think that is covered under warranty. It gets rusty bec. first of all that is unpainted/untreated iron and the moisture (it drips out of the exhaust tip) comes from a sign of good combustion.
You can use a fine sandpaper to sand out the surface rust and apply marine grade on the surface that you can reach.
Even if you leave it alone, it will probably take more than 15 yrs to rust through.
Hindi naman ako nabaha as in yung nabaha talaga. Since nabili kasi maulan yung panahon. Kapag malakas ang ulan at feeling ko baha sa kalsada iniiwan ko lang sa bahay. Kaya nagtaka ako nung napansin ko kasi yung adventure namin eh 6 years na hindi naman nagkaganun. Il try tawagan yung toyota makati kung ano ang maadvise nila kung kasama ba sa warranty o hindi. Kpag hindi try ko na lang yung advise niyo sa akin. Slamat.
Hi Tsikoters,
Guys I'm pretty sure Vios 2007-2008 na bibilhin ko. ang dami ko cinonsider been through a lot of threads narin pero ang vios ang piankaaffordable,low maintenance, easy ang parts, walang problema, unlike city,accent,civic,jazz parang puro nalang problema ang nakikita ko sa thread nila, dito sa vios puro papuri yung iba pa nga naondoy at still reliable parin until now! I was very surprise at confident na ito nalang ang bibilhin ko.
I want to buy a 2008 model. I have 400k budget max. AT sana ang bibilhin ko. Ano mga common problem ng AT or ok ang feedback ng AT na vios? 1.3G, 1.5G ano ba maganda model for AT?
for me and downside lang nito e ginagawa siya taxi kaya sobrang common nya sa daan other than that performance wise hands down ako.
Thanks sa mga magfefeedback!
anyone who has a Baldwin BT223 filter for vios to spare?kindly pm me how much...TIA
