Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    #21
    20vanda01,
    Hindi naman ata ganoon kabilis ang takbo niya. Nasa Pampanga siya that time. It tracked straight pa naman daw so he had time to stop.
    #22
    Quote Originally Posted by nikko m
    the interior looks exactly same as the old hilux.basically wagon na hilux.
    because the Surf is really a Hilux
    #23
    at least that generation of the surf is... halos hilux lang na nilagyan ng roof sa likod. yung '96-'02 and the current surf are more differentiated
  4. #24
    You can go to 4x4wire.com. Dami ng forums regarding Surf/4Runner. 2L engine, issue dyan yung cylinbder head. Pag 2nd hand at hindi naflush/drain ang cooling system it can cause a crack head. Thermostat din sometimes nagma-malfunction. Direkta mo na so when you turn on the AC takbo na yung aux fan. Sa auction ingat nga sa conversion. Most of the units nakita ko may welding sa steering column. Generally ok ang feedback sa UK ng Surf. Yung 3.0 engine, 1KZ better. Corrected na yung problems with cooling lines inside the head so less ang tendency tooverheat and crack.I attended an auction, one unit was bought for 420K. Yung mga 2L, yup 320-350K.
    #25
    Quote Originally Posted by garyq
    meron ding 2LT (turbo).
    mas maganda sana kung 1HD-T like lc80's.
    #26
    [SIZE=3]mga pards.. please HELP...[/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3]meron akong toyota hilux surf na de gasolina, 3Y ang engine. gusto kong palitan ng DIESEL engine. Anu ang bagay dito para ma SAVE ko ang TRANSMISSION nya.[/SIZE]
    [SIZE=3]Para ung ENGINE na lang ang bibilhin ko...[/SIZE]
Toyota Surf question.....
