Results 1 to 10 of 15
- Apr 2012
- 94
April 9th, 2013 11:49 PM #1help mga boss.malakas ata sa gas ang oto ko.nu po kaya problem?im a former honda vti 96 user.sold it and bought lovelife kc sbi nla,mas matipid ang 1.3 12valve engine.but then yung php1,000 ko nasa 130kms lng halos empty na.buti pa yung vti ko umaabot pa sa 200kms ang php1,000.help mga sir...
April 10th, 2013 12:42 AM #2
Carb kasi, malakas talaga sa gas mga carb. Tsaka underpowered yan parang bigbody. Usually mga 7km/L.
Kung may budget ka, engine swap ka to 3rd gen 4AFE MT.
Sent from my 3210 using Tapatalk HD Premium
- Apr 2012
- 94
April 10th, 2013 12:56 AM #3ano po ba ang tamang charge ng jets?napalitan ko ng 96 primary 125 secondary.napansin ko lng medyo pigil or mahirap mag accelerate agad.still observing for the consumption as of now..
April 11th, 2013 09:03 AM #4
Dont change the jets. Just keep it stock, make sure the timing, compression, and tuning are in order and FC should still be a respectable 9-10km/L (that was the case with our 1999 AE111 1.3 LE). Problem lang with carbs is that when it's not tuned properly, malakas sa gas. Check also your driving habits and lastly, do a proper FC computation using the full tank method, the Php XXXX amount does XXXkms is not really a good basis to get consistent readings.
- Apr 2012
- 94
April 11th, 2013 10:19 PM #5nu po ba ang stock jets ng lovelife 2001 xl?not sure rin po kung orig yung napalitan.paturo naman po sa full tank basis computation sir.dati sa honda ko,wtever the price ng fuel, 500 ko til 100kms,thats the time ako refuel.y others claiming 12-14kms per liter sa corolla 2e?
- Feb 2012
- 11
May 9th, 2013 02:46 AM #6
same problem tayo.. 9km/l city driving ko dati after changing timing belt and adjusting distributor bumagsak sa 5km/l ang fuel consumption ko grabe sobrang lakas.. may nag tip sakin pa set ko ignition timing babalik daw sa dati. ang problema wala ako mahanapan talyer na gumagamit ng timing light for ignition timing lahat sila bumabase lang sa menor ng oto...
May 9th, 2013 01:10 PM #7
Kaya naman pala lumakas dahil nag re-jet ka. If you re-jet a carb, you should also be aware that you are altering the design. Bigger jets, means more fuel, more fuel means more air (for it to be burned in an efficient manner). If you introduce more fuel, but still the same amount of air, you will have rich mixture problems. Okay I will not get technical on this baka malito ka lang lalo.
The original jets of a corolla are 80 primary and 110 secondary, correct me if Im wrong. Those jets are designed to give optimum fuel efficiency, while not sacrificing engine performance ....... provided that your carb is well tuned. Problema ngayon, lahat na tao halos nasanay na sa EFI, konti nalang may alam on how to tune a carb.
I suggest, you revert back to the original jets, and have your carb tuned.
- Apr 2012
- 94
May 13th, 2013 03:23 PM #8thanks sa info..may prob din po ang carb ko.yung butterfly/plunger di normal ang function.sbi nung electrician ko.dapat nakasara kapag nakamenor.tama po ba?di nya ginalaw kc not in his expertise..
May 14th, 2013 09:30 AM #9
- Apr 2012
- 94
May 16th, 2013 10:43 PM #10carb overhaul done.lumakas ang hatak.still observing the consumption..di na rin maxadong shakey ang makina kung loaded..
high idle RPM at engine start
