hehehe.. parang yung nangyari sa amazing race... ehhee. although....gasoline in a diesel engine......
Hello:
i recently had a 2" ome suspension lift on my 70 series lc. i was wondering
if i could fit 285-75-16 on it without any further mods. it's currenty on 265-75-16 tires and they look kinda small with the lift.
thanks fro your replys.![]()
285's should fit. But 285's from different brands usually have different overall outer diameters so test fitting is still a must.
mukhang kasaya naman yata, better if you go to the tire shop and fit one...
check mo din width ng rim, a 7" fitted with 265, is considered "sakal" na daw
RedHorse::: 7" rim width can accomodate 285 tire width, the only problem I see is the tire overall width which will not get its maximum width traction but gain in length mark. I'm running on 33's which should reach almost 305 on metric scale mounted on stock 15x7 wheels.
gts::: Will your truck be used on city street or occassional mud/trail? What brand/s are you more inclined to use? 285/75R16 can fit into 16x7 rims without any problems.
on paper kasya...
actual fitting is still your best move.
baka nga kasya pa ang 34 incher na simex diyan eh.
pics and specs naman ng 70 series mo...
magkano mo nakuha? converted ba?
70 series meaning short wheel base siya?
anong lift ang ginawa mo suspension lift o body lift?
Remember how my ride looks when tsikot.com had its first GEB/carshow? 34" Simex nilagay namin nila Kits that time on 15x7 rims. :D
Gts,
I read something from you kc i wanted to ask also which is good mags for my rides kasi i have stock mags which is 235x70R15 and i want to change it to a bigger one can i ask you and give me some suggestion which size of mags i prefer kc i prefer 18" mags
Gts,ang rides ko eh isuzu crosswind XUVi can you suggest which one is gud for my rides
sir,Originally Posted by gts
kasya 285x75x16. correct me if i'm wrong. stock mags niyan 16x6.5. better change the mags too. pang LC80 mags kasya din.
siguro hanggang 305x70x16 kasya. malaki naman ang wheel well ng LC70.
pajero ko naka 285x75x16 bridgestone mud terrain tires. fits perfectly on stock fieldmaster mags.
Hilow! Just wondering, magkano kaya ang Land Cruiser ngayon? Yung box type? Di ko alam ang model nun e pero yung yung naka lawit yung front fenders. Kahit semi restored lang o yung tipong gagamitin nalang pagkabili with just minor repairs.
Tinkyu!!!![]()
i think ur talking about the lc70 series... if that's the one, auctioned ones lang naging available sa local market. you could get one for as little as 350k to a high of 500k, depending on the condition.
check out the Land Cruiser model you are looking for here:Originally Posted by kupaloids
http://www.off-road.com/tlc/body_styles/
but i guess you are referring either to the 40 or 70 series.
How about the 80 series? any comments re: maintenance, parts, performance, price?
bro, the price depends on the condition of the unit. sabi nga ni edwin, from 50k to 500k ang price range.![]()
Yup! I'm referring to the 40 series. Kung sakaling aabot yung budget ko, I might try to buy that model. Sa palagay nyo ok pa bumili ng ganun? O bumili nalang ako ng kotse na mas modelo? My next target is a corolla. Yung GL o XL5.
mainam ang LC80 on and offroadOriginally Posted by karl88
mas mahal nga lang, 6 cylinders din siya.
price, 500k-P1M up
depende..
