Results 1 to 19 of 19
    Just need some information. How much would a 1992 Land Cruiser cost. I am not very familiar with the model but it is the big body (not the square one). The it has a 6 cyclinder gas engine and the emblem on the back is GS or GX (I forgot) and it say 4500. Is this a good 4x4?
    Appreciate any and all your insights.
    Thanks,
    paul
    Marami kasing Land Cruiser models at any given time, eh. May LC70 series a.k.a. Land Cruiser II, may LC90 series a.k.a. Prado and there's the LC80 a.k.a. the 'mataba' (just like lc80's).
    I think LC80 yung sinasabi mo since it is not square. Anong market ba iyan galing? Dubai, Japan, Africa, etc?
    Wherever it came from, its a pretty good 4X4. In stock form, it was unstoppable in the lahar trails of Pampanga.
    sulit yan LC80
    yun nga lang kahit 92' model na, mahal pa din eh.
    yung kay lc80 over 950T, dami pa niyang mods
    Thanks for the inputs. Di ba mahirap ang parts? Also can you run the 4x4 all the time? Yung Vitara ko kasi the manual says only on mud or loose gravel.
    paul1,
    If you get a local version, hindi fulltime ang 4WD niya. Madali naman makita ang fulltime sa partime, eh. Walang manual hubs sa harap ang fulltime.
    Parts are readily available at your Toyota Dealer dahil naglabas sila ng ganyang model dati.
    Original LHD versions still cost around 1.2M (local) to 1.5M (Dubai or Africa) sa second hand market. Mahal yung import kasi fulltime 4wd, locking diff, dual fuel tank, winch and kung ano-ano pang matitinding features.
    Yung kay lc80 is an ex-Japanese version (converted) kaya mas mura ng kaunti.
    all time siya 4x4
    di lang mahirap parts niyan mahal pa,
    pero ok lang
    Quote Originally Posted by paul1
    Thanks,
    paul
    definitely you are referring to an 80 series.
    meron din VX which they say is rare compared to GS/GX.
    it is powered by 1HD-T turbo diesel, 4.2ltr.
    i have no info on its petrol.
    im sure lc80 can add more info since he uses one.
    Thanks again for the infos.
    Yun bang 1.2 to 1.5 applies to the 92 model? Mahal pa pala kalit 10 year old model na. How do you know kung africa or dubai? I'm n vot sure about the fulltime 4x4 and locking diff (don't know what to look for) but i definitely saw two fuel gauge. One on the dash board and one near the rear view mirror. Also ganun ba talaga yung loob bare masyado, wala pang aircon sa likod?
    paul1
    paul1
    You might be referring the African model it is bare, like the GX model. I have read from a magazine that it has 2 fuel tanks (main and auxiliary tank activated by a switch). You need to look near the dash board, there is a knob that indicates OFF, RR (diff lock), FF + RR (diff lock).
    paul1,
    i have the VX model with the 4.2 liter I6 engine.... mas bare nga yung mag GX and GS model. yun ang gamit ng mga redcross wala atang fender flares usually... alam ko not all models have locking diffs so tignan mo muna... may mas higher model pa VX limited. may cooler sa console box and may electric winch. Yung aircon wala rin ako sa likod.
    So far ok naman mga hinahanap ko na parts. nakakabili naman sa mga land cruiser specialist na stores.
    paul1,
    Basta hindi local model at original LHD, malamang Africa or Mid-East model iyan.
    Local LC80:
    *Manual locking front hubs
    *Dual a/c
    *10 seater configuration
    Kung Mid-East model iyan, malamang sulat Arabo yung mga identification plates sa engine compartment at door jamb. May sticker din usually ng Araco (the local Toyota arm there).
  13. Jj is offline Verified Tsikot Member
    Join Date
    Jan 2003
    The local LC80 comes only with a 4.2 turbo diesel engine only right?
    Jj,
    Yep. Good for around 155 bhp yata ito.
    Dec 2002
    Jj,
    Yup, it's called HDJ80 series with 1HD-T engine, 4.2L turbo. Basically a reliable engine if cared for properly.
  16. Jj is offline Verified Tsikot Member
    Join Date
    Jan 2003
    Quote Originally Posted by Ungas
    paul1
    The 92 model of the LC would go for as low as 650K to a high of around 900k-1m. dependin on the condition.
    masyado mahal ata niyang 92 LC80... 1997-1998 LC80s go for 1.1-1.3M pesos i think.
    165 hp/268 lb-ft yung 1hd-ft 4.2L diesel...
    Dec 2002
    The local LC80 and LC100 have the same engine designation, 1HD-T, specs as quoted above. TMPI didn't bring in the updated version, 1HD-FTE, which has an ECU-controlled injection system. Safer for us since no one has the right equipment to calibrate the new computer controlled injection systems.
    Jul 2006
    Hi, meron ba kayo ma-recommend na good mechanic ng LC 80 Gas 3F engine 4L carb?
    Saka madami pa kaming papagawa, fuel system, brakes, aircon, sounds. I hope I can get a reply soon. Thank you!
Toyota Land Cruiser
