Results 81 to 87 of 87
- 54,281
April 18th, 2019 09:09 PM #81i'm not gas, but
i dare not drive my 2005 D4d MT beyond 100 kph. it sounds like the engine is about to fly apart, and the body didn't feel solidly planted to the ground anymore..
my comfortable speed is a measely 60-70 kph, where the rpm is less than 2000. so dun ako sa lolo lane.
but hey! matipid sa krudo in the city.
besides, the aircon was good, dzmm was entertaining, and i wasn't on the clock.
i am confident, i can do better than 110, but si driver na ang natatakot...
in comparison, my 2011 D4d AT could do a comfortable 90-100 kph, with the rpm just a bit higher than 2000.Last edited by dr. d; April 18th, 2019 at 09:16 PM.
- Jun 2005
- 3,774
April 19th, 2019 09:41 AM #82
April 19th, 2019 02:55 PM #83
The new Innova 2.8L is quite fast for an MPV. I have seen some on NLEX/SCTEX keeping pace with the new Montero Sport. There is one time, I think both Innova 2.8L and Montero Sport 2.4L were doing around just below 160 kmh.
April 19th, 2019 05:06 PM #84
- Apr 2010
- 4
April 19th, 2019 06:09 PM #85experience ko din s Forty ko, walang power naka 3000-4000 rpm na pero nasa 90kph lamg ang takbo.. my brother suggested to pump the fuel filter, ayon bumalik ang hatak.. after thhat linalitan ko ang fuel filter and gas filter, OK na ngayon.. CASA suggested e down ang tank para malinis kc may dumi na..
April 20th, 2019 12:59 PM #86
The culprit might be the fuell filter. Nagtanong tanong ako medyo mahal siya (4.5k original) hehehe
Noted the following too and thank you for your inputs:
*timing_gear: ipapalinis or palitan ko na rin spark plug. Nasa 77k pa lang kasi odo nya
*dr. d : It still feels solid naman yun lang maingay na kapag nasa 110 kph. It averaged 12.2 kpl (highway)
*sirkosero : Next step is cleaning ng MAF at TB
*Gumusut_amige: Tagal na rin hindi daw napalitanIt's about time na nga.
- May 2015
- 146
April 21st, 2019 12:20 AM #87Innova 2.5 D-4D TPLEX run
160kph around 3.5k~ ish na yung rpm. May ibibigay pa siya. Pero nakakatakot hahahaha. I'm carrying 6 passengers that time including myself
Sent from my Redmi Note 5 using Tapatalk
Thread was made nung 2018 pa po sir.
