Page 1 of 3 123 LastLast
Results 1 to 10 of 87
    Coastal Road - 140 kph, hanggang dun na lang ...scary
    Jun 2008
    Kelan lang po...
    J, 2.0 gas, M/T
    160km/h, somewhere! 5000rpm...ang ingay!
    160/90 yata blood pressure ko...hehehe:D
    Just a thought... I noticed that some mentioned that it was scary to hit speeds of over 150kph on the Innova. What were the road conditions when you tried doing your run? What tire pressure do you guys use on your car (i run 33psi, cold, on all fours)?
    During a recent trip to Bataan and Subic (via SCTEX) our Innova J diesel was happy running at an indicated 150kph when the road was wide open and it hit a little past 163kph at redline on 5th gear at a certain portion (and this was with a dirty air filter). The car was very stable and i was confident with it's stability with the stock tire and alloy rim set-up (no death grip required on the steering wheel). During my return trip in the afternoon though it was different as the weather was cloudy and here i noticed i was only comfortable at around 100-120kph. The difference between my morning and afternoon trip was the weather; any car is susceptible to crosswinds (and the SCTEX is notorious for this due to the mountain and open terrain surrounding it) so be very aware of this as one strong gust can throw you across to the next lane.
    On a sidenote, the Innova speedo runs quite faster then actual speed so at at an indicated 160kph on the speedo, one would probably be doing 150kph or less from the looks of it (with the stock 205/65R15 tires).
    Aug 2006
    ganda naman ng stolen pic ni vinj. ano camera gamit mo??
    mostly topspeed ng innova 160. pati kapitbahay namin 160 lang din. sobra ingay na daw makina..
    Quote Originally Posted by Xt7 View Post
    Thanks. That was on the SCTEX Zamba/Bataan bound lane one fine Sat. AM; my wife took it with our dying Canon 350D (using a 28-105 lens). That was the speed already slowing down as the camera was on it's manual setting so she had to adjust the exposure to get the shot.
    On a side note: I used up almost 1/4 of my fuel in that run from Pampanga to the Dinalupihan exit of SCTEX (i left Manila with a full tank, drove NLEX lightly, entered SCTEX with my fuel pointed still at F, exited SCTEX at Dinalupihan with my fuel gauge near 3/4). The Innova can really gurgle it down if driven WOT (even if its a diesel). But at the end of the trip and with some city driving involved, i still managed to get around 14++ km/L.
    On the tire pressure, i noticed the ride comfort changed considerably between 33psi and 34psi (cold) with the stock Yokohoma Tires thats why i keep it at 33psi.
    160 isn't bad... and after you hit it you then start to switch to fuel eco mode .
    If you're looking for a good reason to drive on SCTEX before fuel prices goes up higher, try visiting Mt. Samat in Bataan if you (or your family) have not done so. It's a good reminder for everyone. Just make sure your tires and belts are in good condition if you plan to do any high speed runs.
    Shot courtesy of Bluestar of nissanbayan
    Jun 2008
    [SIZE=5]Ganda ng shot!!![/SIZE]
    In my run...I woulda tried 170 or something...but I'd rather save my life and not wreck the car!!!
    Tingin ko po meron pa ibibigay ang Innova namin past 160km/h...5000rpm pa lang naman eh...pero di kaya ng tuhod ko!!!
    lagay ko na rin po ang mga iba pang infos tungkol sa run ko:
    tire pressure: 30psi (masyado po ba mababa?)
    fuel: Petron XCS (95 octane)
    passengers: ako lang
    weather: clear (no strong winds)
    Oct 2005
    160kph, coastal road-'05E diesel M/T
    We did a 160 kph sa SCTEX three weeks ago para masubukan nga ang speed ng Innova G vvti namin. But then crosswinds in the place are prevalent at any time dahil sa mga mountains / valleys along sides of the road. Medyo nakakatakot kung isasagad mo pa ang speed a little bit further.
    Passengers: 4
    Gas: Shell unleaded
    tire pressure: 32 psi
    at any cruising mode na nasa 80-120 kph, all i can say is , very smooth ang Innova dahil napakaganda ng daan sa SCTEX.
    Bihira lang po ang mga cars travelling that place and it is a good testing ground for Innova Top Speed. Try po ninyo dun besides the beautiful sceneries na makikita ninyo from Clark all to the way to Subic.
    Sep 2011
    my DIESEL 2012 innova E variant did 160kph with 5 passengers during the "hard break-in" two days since I got it and having 200km on the odometer...
    Today, i did 165kph with 7 passengers at almost 4,500 rpm and 1900 on the mileage...
    Comment lang pards: Better to hold the steering wheel with both hands at near to the 9 and 3 o'clock positions as much as possible, especially if you're doing a high speed run. That position allows you to be more deliberate and controlled with steering inputs, especially on a high-centered vehicle like the Innova where you cannot do sudden jerks at speed that may unbalance the car. At low speed, this also allows you to move the steering wheel more efficiently without losing grip on the wheel at any given moment
Toyota Innova Top Speed
