Results 1 to 12 of 12
    Jul 2015
    Hello... recently, I went to a car aircon cleaning service. To be able to complete the cleaning process, they have to pull off the whole dashboard. When they are finished cleaning, they were able to successfully put everything back but except for one screw in the odometer, they told me there was no screw before when they open it. I don't wanna argue with them because I also don't have any evidence if they misplaced, lost the screw or it was not really there.
    My question is, where I can buy a screw/binder replacement(whatever it is called) of my car's odometer? When I am driving my car, there is an irritating noise near the odometer since it was not clipped.
    My car is a Toyota Altis 1.6G 2003 year model. Any help will be very much appreciated.
    Quote Originally Posted by konichiwa888 View Post
    try the casa, po. their computerized parts identifiction system is great.
    if they don't have any,...
    try the second hand (cathay/katay) centers in banawe or evangelista.
    be prepared to pay thru the nose, as these guys know you're going to them because you can't get the part you need anywhere else.
    Jan 2016
    Try screwtech, google na lang which one is nearest you
    Casa will give you the correct part/ size.
    If you are diligent scrimping some bucks, then search for the part number and you may be lucky finding the size specs from the supplier.
    Another option is to get a sample by removing the screw next to it then check for equivalent at local screw shop like Tosuy, Wilmar.
    Most of the times an old screw laying on your toolbox garage could be a substitute and do just fine anyways no one would notice since its under the dash, and its free.
    Nov 2017
    The screw at the top is p/n:93568-55018 or (5891012820B0; 9016845005; 9356755018; 93568-55018; 9356815018)
    The spring/washer that goes with it: 90183-05033
    The two clips at the bottom: 55345-12060
    Jan 2008
    Yung metal na kinakapitan ng screw.. pwede kayo humingi sa mga audio shops.. dami sila nung kasama sa mga replacement speakers na screw tap..
    Jul 2015
    Quote Originally Posted by LOLZ View Post
    Thank you for the very informative posts. Will try to look for these parts in screw shops like TO SUY.
    Jul 2015
    Thank you for the information. Really appreciate it. Will first try TO SUY, then if wala, will try casa if they have available parts. Will keep you guys updated if nakahanap ako. Thanks.
    Nov 2017
    maybe the local hardware can match an appropriate screw from a photo?could save a few bucks that way
    i have this thing, put together by screws.
    four holes. four screws. four different ones. because i previously lost three of them.
    but it does the job, naman.
    Aug 2017
    Mahusay! Magaling! Salamat!
    toyota tries to simplify its manufacturing stocks, by using and re-using the same piece, for as many uses as possible.
    your particular screw, is probably the exactsame screw used in other areas of the car.
    as such, it is probably easier than you think, to find a replacement.
    if you can bring a sample of what you want, even the non-toyota parts counter might be able to give you a replacement.
    good luck.
Toyota Altis 2003 Model (Where to buy screw of the odometer?)
